2010 Engine Rattle
5 replies to this topic
  • luckyguy19
Posted September 19, 2011 - 07:39 AM
When I shut off my 2010 YZ450F there is a bit of a rattle right as the engine winds down. It sounds like the cam chain. The bike runs perfect everywhere else, its only in shut off that I hear this noise. Anyone else hear this? It sounds similar to the chain slap my buddy has on his KTM 450 XC-W. I just hope its nothing to worry about.
Posted September 19, 2011 - 07:51 AM
It's more likely to be the transmission and primary gears bouncing off each other. Any engine with fewer than 6 cylinders or more runs at a very unsteady speed at low RPM, accelerating on the power strokes and decelerating as it hits compression. The fewer cylinders, the more exaggerated the effect. Same is true during shut down. I haven't heard yours, but the description sounds typical.
  • luckyguy19
Posted September 19, 2011 - 08:22 AM
I only hear it after I've already pushed the kill switch. It really only happens for a second or two right before the engine completely stops turning.
Posted September 19, 2011 - 12:35 PM
I understood that. Same answer. If you are concerned about the cam chain, though, you can open the cam box up and check it out.
  • luckyguy19
Posted September 19, 2011 - 02:21 PM
Sounds like its nothing to worry about. I did a valve check about 15 hours ago and they were all spot on, typical Yamaha.
  • rider47
Posted September 20, 2011 - 09:59 AM
My 2010 doe's the samething since new! 51hr and counting.
