Radiator Drain screw?
6 replies to this topic
  • hoosierdude22
Posted September 18, 2011 - 06:07 PM
Is there a drain screw for the 2002 wr426? I can't seem to locate it. If not, what is the best way to flush the system?
  • nnamssorxela
Posted September 18, 2011 - 06:53 PM
I believe you can just undo the small bolt on the water pump on the right side of the motor. Removing the radiator cap will help relieve pressure and allow the coolant to flow out.
In this picture you can see the water pump...
^^^obviously not the a wr but you get the idea.
  • hoosierdude22
Posted September 19, 2011 - 06:00 AM
That is what I was thinking I would have to do. My brother has a KTM that has an actual drain screw, so I was hoping mine had one to and I was just missing it. This seemed like what I would need to do and really isnt all that bad as little as I need to do it. Thanks for your reply and your time!
  • 2smokeforlife
Posted September 19, 2011 - 06:08 AM
there should be a bolt in the bottom center of your water pump that has a copper washer on it that is the drain.
  • 2smokeforlife
Posted September 19, 2011 - 06:11 AM
here is the parts fich number 11 is the bolt and 10 is the washer
  • hoosierdude22
Posted September 20, 2011 - 05:43 AM
That is what I was hoping for. Thanks a bunch for taking the time to grab this picture. I looked at that bolt but thought it was something to do with the mounting of the pump iteself or even a case bolt. I know where this is and will tackle that this evening. I appreciate your help here.
  • 2smokeforlife
Posted September 20, 2011 - 09:10 AM
No problem:thumbsup:
