Need Help with Suspension Settings
2 replies to this topic
  • mxcowboy
Posted June 28, 2001 - 06:05 PM
Hey guys, I was wondering if anybody could help with the settings on this 2000 yz426f beast. i'm 6'1", 230# and a novice rider riding mx.Is there anybody close to that and knows what their clicks are set at so i can use that as a starting point. The suspension has been gone thru by scott suspension before i bought the bike... thanks for your responds...
  • bjscheel
Posted June 28, 2001 - 08:32 PM
Hello i wiegh 250 pnd's and 6'8". I have my thread count on the shock set at 13 threads from the bottom and comp at 4 clicks out rebound is at 5-6 out depending on the day. i have installed delta valves in the forks with a 7 weight oil. maybe that will help you good luck.
  • Bill
Posted June 29, 2001 - 02:33 AM
For the initial setting use the email address in my profile and I'll check when I get home. For tuning information, go to MX-Techs web site and they have a complete guide on tuning. Print it out and take it to the track.
I'm 10 pounds lighter than you but, my settings should get you close.
Bill
99 WR400f, YZ timed, MX-Tech suspension, Scotts steering damper, White Bros E-Series (12 discs), tapered header and a/f. Kouba T-handle for the fuel screw. Works Connection billet throttle tube and frame guards. Cycra Pro-Bend, triple clamp mount handguards. Thumper Racing rad guards, Renthal Jimmy Button highs, YZ Tank and IMS seat, YZ number plate, odo removed, EKP, 48PJ, 175MJ at 500-1000' Thanks James Dean!
  • 9 replies
  • 0 replies
  • Hot  50 replies
