Does anyone know..........
3 replies to this topic
  • ChuckZilla
Posted September 10, 2011 - 07:07 PM
If the hex head inspection plugs for the stator cover from an 09 YZ450 will fit in an 06 stator cover? The 06 has the plastic slotted screwdriver type where the 09 has allen hex steel plugs I believe. Mine are kind of torn up. Anyone?
  • jratcliffe3
Posted September 12, 2011 - 12:21 AM
Don't know if the 06 will fit the 09. The 09 part is poor though, I think it is aluminium rather than steel as you state - mine rounded out the first time I tried to undo it - ended up having to loosen it with a punch, so you are not the only one it has happened to.
  • ChuckZilla
Posted September 12, 2011 - 03:24 PM
Thanks for the reply. Yes I think the 09 hex plugs are aluminum, but aluminum has to be harder than plastic. I looked around and the aftermarketers specify 06-09 so I'm assuming they fit. I'll order some and see what happens.
  • ChuckZilla
Posted September 16, 2011 - 11:21 AM
The answer is yes, they work perfect.
  • Hot  50 replies
  • 0 replies
  • Hot  30 replies
  • Hot  36 replies
