2007 CRF250 Fork Oil Level
1 reply to this topic
  • scottie238
Posted September 03, 2011 - 04:37 PM
I am replacing the fork seals on a 2007 CRF250. How many mm from the top of the fork tube should I set the oil level? It is for a 150lb rider who rides a mix of track and desert. Also, what are the stock rebound and compression clicks set at? How many clicks would you recommend for this size of rider? Thanks for your help.
  • 455
Posted September 03, 2011 - 05:24 PM
Fill outer chamber by cc's not a from the top measurement.
Start at 350CC set both clickers at 12 out.
