O-ring chain
3 replies to this topic
  • luvmythumper
Posted June 25, 2001 - 09:16 PM
I purchased a DID X-ring chain. I have been told not to clean it like I did my other chains and that it only needs to be oiled every 2-3 rides. How do you guys take care of your O-rings?
  • SUnruh
Posted June 25, 2001 - 10:39 AM
i had a DID X-ring chain last more than an entire harescramble season doing the following:
after washing the bike, spray WD40 on it till it drips (to prevent rust). that was all. the chain was as tight in december as it was in march.
  • MotoStyle
Posted June 25, 2001 - 08:10 PM
With O-Ring chains, avoid spraying high pressured water directly into the links. Otherwise, wash your bike as you'd normally do. Then, just as you'd lube your chain, use WD-40 (as previously directed) since it's doing two things. It forces all of the water out of your chain and it lubricates it as well. I rarely ever use normal chain lube on my O-Ring. Just WD-40 and that's it. Do Not use a wire brush whatever you do. You'll destroy the rubber O-Rings that make the chain work so well. :)
  • wpattison
Posted June 26, 2001 - 04:07 AM
ditto all of the above.
will pattison
racer, engineer
  • Hot  79 replies
  • 9 replies
Need help by Goforaride
  • Hot  68 replies
