iphone 4 charger on YZ450
25 replies to this topic
  • chrispa
Posted August 29, 2011 - 02:14 PM
Has anyone ever installed an iphone4 or equivalent mobile phone charger on the standard alternator coil on a YZ450? (or equivalent 450 dirtbike)?
I'm not sure the coil will be able to handle the charger + existing headlight (which I have on the bike).
  • Thepowderblue
Posted August 29, 2011 - 03:00 PM
It should be able to. Its only like 3 or 4 volts. I bet you could just put a 12v outlet on and run alot bigger stuff like big spotlights and little air compressors. If something is using to much power just have a switch on the headlight so you can turn it off and on when you want.
  • ttr250dude
Posted August 29, 2011 - 06:33 PM
No. The coil is built to only handle the ignition system on these bikes. How are you running a headlights on a YZ450f coil? I can only assume your damaging something by putting too much strain on the ignition system because of the headlight.
  • dalonar
Posted August 29, 2011 - 07:49 PM
"•14 volt / 110W high output generator powers the battery less fuel injection system."
  • stlyamadude
Posted August 29, 2011 - 07:50 PM
I put a freakin trail tech vapor on my 08 450 and it wouldn't run at idle with it...lol I ended up running the vapor off a 9 volt bat and had worked very well...pretty funny that a 9 copy will run it but the bike wont...lol ya what he said.....how r u running a head light unless its a wr??? Bike is only made to run itself and thats that...I found that out last week ........
  • stlyamadude
Posted August 29, 2011 - 07:51 PM
Ok...didn't see that post....I feel stupid.....lol. awsome.
  • chrispa
Posted August 31, 2011 - 03:00 AM
system can handle low power consumption front LED front and rear tail light, didn't know the output was that low, bike will stall then if I hook a charger to the coil.
thanks guys
  • Thepowderblue
Posted August 31, 2011 - 10:42 AM
Well It might work if you turned the lights off
  • magiksc
Posted August 31, 2011 - 05:30 PM
I'm running this 12v socket from Rocky Mtn. ATV on my WR model. Installed in 15min and charges my phone and my Go Pro when I'm out on long rides. Just connects to your battery.. if you have one
http://www.rockymoun...286&brandId=294
  • chrispa
Posted August 31, 2011 - 11:50 PM
no battery on the YZ450 :)
  • ttr250dude
Posted September 01, 2011 - 12:03 AM
The WR has a higher output coil for lights and stuff. And like thepowderblue said, the YZ doesnt have a battery.
  • motojase316
Posted September 01, 2011 - 02:16 AM
Trade up to a KTM450SX. Battery for ya lol
Posted September 01, 2011 - 06:36 AM
Trade up? You like riding an orange shopping cart, fine. I'll stick with a YZF.
  • Hurricane
Posted September 01, 2011 - 09:35 AM
LOL my thoughts exactly.:)
  • Yamiryder
Posted September 02, 2011 - 04:26 PM
i'm still confused how a yz450 runs a headlight?:)
  • dalonar
Posted September 02, 2011 - 04:47 PM
2009 and earlier years cannot (low output stator)
2010 and later can (high output stator)
should clear things up?
  • Yamiryder
Posted September 02, 2011 - 05:13 PM
ahhh, yes, better now.:)
  • brentn
Posted September 03, 2011 - 09:29 PM
nice
  • chrispa
Posted September 04, 2011 - 01:16 AM
You can run low consumption light kits on any YZ450F, including those with low output stators. The stator can handle the power requirment of the low power consuming LEDs, I have an 08 which runs them fine. Here in Australia/Victoria, they sell these light kits because to ride in the bush, you require a brake/tail light, head light and horn.
  • Hurricane
Posted September 06, 2011 - 10:17 AM
Can you actually see anything with these LED low power lights?
  • On January 15, 2017
  • Hot  30 replies
  • Hot  113 replies
  • Hot  50 replies
  • 10 replies
