hanging idlle wr 400 '99
2 replies to this topic
  • clodeb
Posted August 26, 2011 - 05:01 PM
Still have my hanging idle!! change the pilotjet for a 50 i try 2-3 turn back on mixture screw,i also check intake boot for crack and tight hose clamp.... still the idle don't come down easily. I have the airbox cover remove and i run a Yosh rs3 full exhaust. If i play with needle will it affect my idle!?
or should simply swap for a more recent yam carb ..like a wr or yz 450. It is not fun to ride the bike in tight section in the woods with that fast idle,
All the help you can give me is welcome
  • DB_Cooper
Posted August 27, 2011 - 08:59 AM
"Idle" issues or other "throttle" problems are probably a sign the TPS on your carb is going bad.
Very common problems include, Erratic idle-"Sticky" throttle like a cable is hanging up or "stammering" over rough terrain.
You can unplug it and see if it helps.
  • clodeb
Posted August 27, 2011 - 08:35 PM
What is really that tps thing doing..is it connected to the cdi unit... you see i am from the old school. Mikuni carb with no tps or acc.pump so! This bike is 12 years old so maybe the carb is worn out . Is there a way i can check with an ohm meter that tps thing.or symply the carb need to be change or overhauled!
