light keep blowing on my wr400
2 replies to this topic
  • madmanuk
Posted September 11, 2003 - 02:34 AM
Hi, Is there anyway to stop my lights from blowing i am sick of getting new builbs for it.
Thanks
  • Don400426
Posted September 11, 2003 - 02:59 AM
I think you may have a faulty regulator - or it could be just a corroded wire connector to the regulator.
I've abused my 400 for a couple of years - many 'offs' & hard knocks with no bulb failures, apart from tail lamp - I made an LED light unit for it which works well & has given no trouble at all. Headlamp bulb is still original one.
I wish the big end had lasted as long!
Hope this helps - Don.
  • PumpkinHumper
Posted September 11, 2003 - 09:51 AM
I'd have to say its your voltage regulator also. I think its mounted right near the stearing stem. Its a silver box about 1" square. Check to see if it is properly grounded ie corrosion. If thats not the problem maybe the regulator is toast.
