Holy Spark Plugs Batman
14 replies to this topic
  • GrahamO
Posted September 10, 2003 - 07:08 PM
I knew it would happen sooner or later. Some dork on the production line at Yamaha played a mean trick on me and put a special motor on my new WR450. This special engine has the spark plug hidden deep inside a cave in the center of the engine. I can only assume, like the batcave, that there is some secret to entering the cave to remove the spark plug, but I couldn't figure it out. The manual gives great instructions: (1) Remove spark plug.
Has anyone figured out the secret to entering the spark plug cave?
  • Ronnie Mac
Posted September 10, 2003 - 07:38 PM
It's a secret only bat-girl knows. :lol:No really, did you get a parts bag with the plug remover in it? I did. :)
  • ddialogue
Posted September 11, 2003 - 08:06 AM
Same technique as the 426...same swivel plug wrench too.
  • oldbones
Posted September 11, 2003 - 08:30 AM
Same technique? Am I being a dummy by taking the tank off to get to the plug?
  • tctrailrider
Posted September 11, 2003 - 09:11 AM
Oldbones,
If you figure out how to get the plug out without removing the tank I will worship you as "The Magic Man".
  • tctrailrider
Posted September 11, 2003 - 09:14 AM
GrahamO,
Remove the seat and tank and use the special plug wrench that came with your new bike. This time use your tool set and NOT your lighter.
  • cnacc
Posted September 11, 2003 - 09:22 AM
:D :)
  • GrahamO
Posted September 11, 2003 - 09:38 AM
GrahamO,
Now that's pretty funny. I almost ventured into the cave with a torch to see if I could find anything, but after several hundred yards I still hadn't found the top of the spark plug, so I turned around. I'm sure it's down there somewhere... way, way down there.
Re: the nifty wrench you all got with your bikes. I bought mine slightly used and am going to need to harrass the seller for the wrench. Anything else useful come in the tool pack?
  • tctrailrider
Posted September 11, 2003 - 09:43 AM
GrahanO,
"Anything else useful come in the pack"
Spoke wrench
  • oldbones
Posted September 11, 2003 - 10:38 AM
Mine came with a little baggie of jets. Looks like a 160, a 170, and 38.
  • Garry_on_a_426
Posted September 11, 2003 - 04:38 PM
You can borrow mine if you show me how to change the oil in my '01.... :)
  • GrahamO
Posted September 11, 2003 - 04:57 PM
That shouldn't be too dificult:
(1) Punch a hole in you gas tank, covering your bike in gasoline.
(2) Throw a lit match at, preferably from a distance.
(3) Now you don't have a reason to change it. Buy a WR450.
  • Garry_on_a_426
Posted September 12, 2003 - 06:21 AM
But I can't put a plate on the 450 otherwise I would have....
Believe me, I have only had the bike 2 months, and have had more than 1 occasion to say !@#!@#$%ing kick start....
  • GrahamO
Posted September 12, 2003 - 07:06 AM
I know the feeling. If my 426 was hot I'd push start before kick start. Two ironic things... (1) the e-start ain't that great. The kick start is so easy now the e-start is a waste of weight (2) My 426 would have whipped my 450 in a race. It was YZ timed with Race Tech suspension and jetted perfectly. Bad A$$... once you got it started.
  • Garry_on_a_426
Posted September 12, 2003 - 07:51 AM
I don't have any of the engine mods, but just about everything else
Ty-Davis hot start
DSP exhaust
Oversized brakes
ACME suspension
4 Gal IMS tank
Scotts tripple clamp/Damp
Acerbis hand guards
Skid plate
Baja Designs kit
Trail tech computer
and a calif plate :)
