'01 426 rattling underneath
17 replies to this topic
  • nathanpa01
Posted August 20, 2011 - 09:33 AM
At idle and pretty much throughout the RPM range, I have a rattle or "chuchuchuchuchu' (If I had to spell a sound). I do not live near railroad tracks nor have Thomas the Tank Engine soundtrack playing. Are we talking rod bearing/crank bearing/time for a new crank assy? I know the 426 is a mechanical sounding motor and the skid plates reflect engine sounds, but I believe it's been growing noticeably louder
  • nathanpa01
Posted August 20, 2011 - 09:39 AM
regular oil changes and yes, fine metal particles in the filter but never excessive amounts IMO. To do a crank replacement, what else should I do while it's split? cam chain is still tighter than a nun and the marks are spot on.
  • banda
Posted August 21, 2011 - 05:55 PM
Have you had the case covers off? On a 2000 426, the counterbalancer drive gear is mated to the crankshaft with a key instead of splines. That key gets bent and the drive gear clacks around - probably not your issue if you have a 2001.
On the other side of the motor, I had a pressed-on interference fit oversized flywheel weight come loose once, and it made a hell of a clatter.
I also once had a clutch spring bolt work loose, and it contacted the clutch cover when the clutch was disengaged. That was a fairly awful clatter too.
Are the valve clearances in spec? That can make some noise.
I know from experience that a rod bearing doesn't make a lot of noise before it lets go - the bike loses power gradually for a while, and then it just locks up dead one day. That's not so much fun.
I hope you find the source of your noise, and I hope it's one of the easier, cheaper things to fix.
  • nathanpa01
Posted August 21, 2011 - 08:39 PM
The covers are coming off this week. I figured I would be finding more shavings in the oil if it was bearings too. Working too damn much to spend time in the garage. Good thing about working too much to play, is that i'm not spending money on any of the toys.
  • nathanpa01
Posted August 21, 2011 - 08:43 PM
I'm not opposed to a tear down and rebuild actually. I've never had it all apart before. And as far as a rod bearing not making noise before it goes, i'm sure it varies from situation to situation. For example, but not specifically, my Tacoma makes a lot of valve noise, but they are all in spec.
  • pembell
Posted August 22, 2011 - 08:24 AM
Probably a bit obvious, but the nut on my front sprocket managed to get loose once and that would rattle on the overrun in particular, or when idling.
Like I say, probably a bit obvious, but take a quick look anyway!
Posted August 22, 2011 - 08:30 AM
On a YZF, a loose front sprocket will cause a huge oil leak. The transmission is pressure fed.
  • pembell
Posted August 23, 2011 - 12:07 AM
Hmmm. Didn't on mine :)
Posted August 23, 2011 - 06:38 AM
I does have to loosen up about 3/4 turn on the nut in order to leak, but not much more than that. Possibly the lock washer kept it from going that far.
  • nathanpa01
Posted August 23, 2011 - 07:36 AM
The front sprocket is tight. Do I NEED to buy a case splitter? Or does patience and a little time work too?
  • banda
Posted August 23, 2011 - 07:46 AM
You can split the case by hand, and take it to a shop to have the crank pulled. Hopefully you'll find the problem before it gets to that.
  • pembell
Posted August 24, 2011 - 01:52 AM
Yeah, I think that was the case. The lock washer had let the nut slip a bit, but not that much. It didn't need much looseness to rattle, though!
  • nathanpa01
Posted August 27, 2011 - 11:39 AM
I pulled the covers today, Stator/flywheel side, everything was clean and tight. Although there was slight in and out movement of the assy, how much is acceptable? The clutch side is a little different. Definite wear and wonder where a piece of the lock washer went. Possibly ground up and that's what I was seeing in the filter after the last change, this filter was clean. It looks like it was filed down once before. Slight in and out movement of the splined shaft.
  • nathanpa01
Posted August 27, 2011 - 11:44 AM
So should I replace it all? Plates and rings look good yet. The aluminum parts are really the only thing worn, and the broken lock washer tab. Could all this be the sourse of my noise?
  • nathanpa01
Posted August 27, 2011 - 06:59 PM
I'm also guessing the blackening is from oil over the years.
  • Stinger1133
Posted August 27, 2011 - 07:11 PM
I put a new clutch in mine and noticed my hub was the same way. I also had the lock washer with a tang missing. I got another hub off of ebay and ordered another washer when I did the new clutch and now all is good. I would recommend replacing it. Mine had alot of play where the splined shaft goes through. The inner part of the hub is a pressed in piece of steel with the splined teeth made into it. Mine was so loose the whole clutch hub and pressure plate assembly had alot of play. I got a hub and pressure plate off of ebay for $40 shipped.
  • nathanpa01
Posted August 28, 2011 - 08:54 AM
I have found a couple complete clutches on ebay. But I am waiting for more pics of the wear surfaces before I buy. I cannot justify spending the money for a Barrnett, Hinson, MSR or even a Wiseco for how often I get to ride anymore. There is alot of play in the clutch on the splines as well. There is also about 1/8" or so of play between the primary and the basket itself, the springs seem to have compressed/shortened.
As far as in/out movement of the splined shaft and flywheel shaft, how much is accceptable? There is a little, but everything spins smooth with no vertical or side to side movement.
  • nathanpa01
Posted August 29, 2011 - 08:10 PM
So maybe I titled this thread wrong. Either way, can someone chime in on the in and out play of the splined shaft?
  • 5 replies
  • Hot  47 replies
  • On January 15, 2017
  • Hot  30 replies
  • 10 replies
