My Ramp Plans
7 replies to this topic
  • BoxcarWilly
Posted 17 August 2011 - 07:38 AM
hey, so im building a little fmx ramp, it's 4'6" tall 6' long and 4' wide. it has five supports 1'2" apart and each one is 9" shorter tahn the last one. the angle is between 30 and 40 deggres ( i think XD) do you guys see any flaws in my design??? please tell me!
  • fmxdave
Posted 18 August 2011 - 08:46 AM
If you're going to build a ramp get real plans from the internet, if you don't want a full size 8+ft ramp just subtract the height accordingly.
  • BoxcarWilly
Posted 19 August 2011 - 07:20 AM
IK i'm not that intense in fmx and this would be a pit bike jump, do you have a link to any good jump plan website or plans that you use? thanks
  • fmxdave
Posted 19 August 2011 - 02:10 PM
there are a few on here, just look @ older posts. the only ones i know of r the ones for a rev 1 ramp. i haven't looked in a long time. check out destruction ramps they have all the stuff you're looking 4.
  • TwoBobRob
Posted 21 August 2011 - 06:41 AM
That would be a whippy ramp for BMX, let alone any bike with a longer wheelbase...  Is it a flat bank ramp, or transitioned?
If the whole thing is 6ft long as you say, I'd suggest you start out with it around 3ft high, ride it then modify as you go.  Unless you want it to be a real kicker.
It does depend a bit on what you're landing on though. If you set it up as a step-up it'll be a lot safer starting out.
  • BoxcarWilly
Posted 22 August 2011 - 07:52 AM
my ramp is for a 110... so... its supposed to launch me high but not far due to space limitations, and im landing on an appropriate dirt landing.
  • BoxcarWilly
and at fmxdave ill check out that site thanks :)
  • TwoBobRob
Posted 28 August 2011 - 01:02 PM
Ok, so a longer bike than a bmx bike then. If you're dead set on 4'6" high, I'd suggest you build your ramp around 8' long. Assuming the ramp is transitioned not a flat bank (wedge), the radius this provides will work a little better.
Still going to be whippy though.
Just to put this into context for you, I build small skate kicker ramps for people. At 18" high, these work out between 4 and 5ft long depending on the user.
