charge rate
2 replies to this topic
  • wr45
Posted August 13, 2011 - 07:08 PM
Anyone know how much Voltage should be going to the battery when its running? Mine only throws out 8-9 volts. Its gotten tough to start, but seems fine after she's warm. Stator? Any help would be appreciated. Should I just replace with an aftermarket ?
  • PBDBLUE
Posted August 14, 2011 - 05:16 AM
It should be 13 - 14.5 volts running mid rpm. Check the stator with a meter and if that's good then most likely the regulator is toast.
  • Just_a_trail_rider
Posted August 14, 2011 - 09:03 PM
Doyou have a service manual? It will tell you how to verify the stator.
The other problem you have may be related to a low battery condition. Do you have to kick start it?
