rebound clicker broke
8 replies to this topic
  • usaf_yz426
Posted August 09, 2011 - 11:45 AM
so i was stiffening up my front forks for supermoto and when i was running my rebound clicker in (left fork), i heard a snap noise and now there is no resistance when turning it in either direction, so i am assuming that it is broke. is there a way to check on this? i don't wanna take the top cap off and be greated with a shower of fork oil to the face, so is there anything i should be aware of? thanks
  • usaf_yz426
Posted August 09, 2011 - 01:44 PM
so what exactly breaks on the inside when this happens? i tried taking the cap off but it seems like spring tension is holding it in, do i need to loosen the compression valve on the bottom of the fork?
  • LemonDrizzle
Posted August 09, 2011 - 02:19 PM
The cap is threaded onto the damper rod so you will probably have to take the fork off the bike because you need to be able to slide the fork tube down in order to access the lock nut to remove the cap.
Here's a really good how to video on cartridge type forks from RockyMountain ATV/MC.
Part 1
Part 2
  • usaf_yz426
Posted August 09, 2011 - 02:26 PM
thanks the vid helped alot, i'll break the shock down when i get home. but what exactly breaks in the rebound clicker assembly? i guess i'll find out when i get it apart.LOL
  • LemonDrizzle
Posted August 09, 2011 - 03:00 PM
While I've never actually had one of the caps apart, I think that there really isn't much to them. I think that all that is in there is basically a screw that applies pressure to the damping rod and an o-ring or two. It's probably not something that can be found at your local hardware store though, if I had to guess I would think that it is threaded at the top and just a bare shank towards the bottom. Like I said, though, I'm just guessing. One of two things probably happened, either the adjuster twisted off or the threads in the cap or the adjuster stripped.
Posted August 09, 2011 - 03:56 PM
It's too complicated a part to jerry-rig a fix for it. You're going to need a top cap assembly. If Yamaha can't get one, or you think it's too costly, check with SMART Performance. Dave is a KYB dealer.
  • usaf_yz426
Posted August 09, 2011 - 04:22 PM
thanks gray, i'll give him a call. i saw that someone is selling a pair of the caps on EBAY for a 100$, is this a good deal?
Posted August 09, 2011 - 06:14 PM
Yamaha retails them for $236...each. Without checking with Dave, I think it's probably safe to guess that it is, but he could surprise you.
  • usaf_yz426
Posted August 09, 2011 - 10:09 PM
Well it is verified, the rebound clicker is toast, also the rubber bump stop was trashed. I'm gonna see what dave can do for me. Costly leasoned learned, be easy on those clickers
  • Hot  28 replies
  • Hot  38 replies
  • Hot  47 replies
