stalling, hard starting 03 450
3 replies to this topic
  • yzjoel
Posted August 07, 2011 - 08:34 PM
This bike has a completely stock motor and a magura hydro clutch. Stalls with clutch in and back brake on. Also stalls when giving throttle at low speeds. What can I do?
  • Octanee
Posted August 07, 2011 - 08:42 PM
i will probably say its a compression/valve issue, also being a 03 450, i would also ask if the valves have ever been done/piston touched at all, if not, im going to say, new piston, rings, valves probably or valves being shimmed, stuff like that is going to be needing to be done
Posted August 08, 2011 - 05:56 AM
I think I'd try adjusting the idle speed and mixture before I went into an overhaul :eek:
http://www.thumperfa.../jetting.htm#PJ
  • yzjoel
Posted August 08, 2011 - 08:35 AM
I appreciate the info. I changed the pilot up to a 45 before the race. It didn't seem to help. I will play with idle speed and recheck the valves. I checked them in June and they were in spec.
  • 10 replies
  • Hot  50 replies
  • Hot  36 replies
  • 0 replies
