Fork Seals
13 replies to this topic
  • climaxx dirtbikes
Posted August 07, 2011 - 12:57 PM
I have an 07 WR 450 with very few hrs on it maybe 50hrs. (not sure) My front left fork seal was leaking pretty bad before I cleaned it and I have lost a good bit of fork oil. My question is can I change the oil in them without changing the seals. I know its really not the best thing to do but Im broke and racing in an enduro Sept.4th. It may be in my head but the front end handles like crap right now.
  • Krannie McKranface
Posted August 07, 2011 - 03:41 PM
Yes you can. Change it in both forks, and go to 130-125mm in both.
  • climaxx dirtbikes
Posted August 07, 2011 - 04:03 PM
Thanks! I have actually watched this video multiple times already. I think I am going to 5wt oil. I saw somewhere how to make a cheap measuring device for oil level and they also said I could use a ziploc bag in place of the seal saver. I cant seem to find this info again. What are your thoughts?
Posted August 07, 2011 - 06:28 PM
I don't believe in seal savers, unless you ride mud regularly, and don't wash and maintain your bike after every ride.
Use a metal rod as a ruler.
  • climaxx dirtbikes
Posted August 08, 2011 - 11:53 AM
When I said seal saver I meant the seal bullet that goes over the top of the fork tube to keep the seal from getting cut when installing.
  • GuyGraham
Posted August 08, 2011 - 12:19 PM
just used a polythene bag to protect the seal, when fitting it over the stanchion
  • climaxx dirtbikes
Posted August 08, 2011 - 01:34 PM
Cool thanks!
  • strtdsmallproject
Posted August 09, 2011 - 06:22 AM
I just used some nylon electrical tape. worked great!
  • climaxx dirtbikes
Posted August 09, 2011 - 01:57 PM
Noted.
  • climaxx dirtbikes
Posted August 11, 2011 - 05:15 PM
Here is the link to the fork oil level tool I am making.
http://www.superhawk...eal-tool-22397/
  • RockyMtnScotsman
Posted August 11, 2011 - 05:36 PM
not a smartass remark, serious question: instead of buying or making a fork oil level tool, what's wrong with just measuring out the specific volumetric amount called for in the service manual and then ensuring that you use it all ?
  • GuyGraham
Posted August 12, 2011 - 03:38 AM
coz you can never be sure how much of the old oil you got out
Unless you strip the forks completely, down to component level, then there will always be some left in the forks but how much you don't know
Further more all components have have a manufacturing tolerance, and lets say you had one fork tube with an ID at bott tol & the other was at top tol, then if you put the same amount of oil in the forks, the levels would be way different because of the different volumes
Its the oil level that determines the 'air spring' effect, not volume, that's why you need to measure the level and not the volume
  • WR450FGreg
Posted August 15, 2011 - 12:02 AM
climaxx,
Re: http://www.superhawk....al-tool-22397/
Man, that is a great idea!
I love coming up with solutions to problems like that, I wish I'd thought of it!
Well done! :eek:
All I've done to date is use a syringe with a piece of clear plastic tube off it the length required. It sucks out any oil below the level I have set.
Trouble with my idea is that it is limited by the length of tube, ie I need different tubes for different oil levels.
Mine is going in the bin and I'm buying myself a large bulldog clip!
:smirk:
Greg
  • climaxx dirtbikes
Posted August 15, 2011 - 02:25 PM
climaxx,
Well done! :eek:
:smirk:
Greg
Thanks! I made mine for $5. I wish my syringe was a little larger although I drilled the small hole at the bottom out to make it easier to suck the oil through. (I learned on the first fork leg)
