pics of my rt2mx
Posted 29 September 2011 - 05:52 PM
Posted 29 September 2011 - 08:47 PM
Posted 30 September 2011 - 03:39 AM
Posted 30 September 2011 - 04:43 AM
Posted 30 September 2011 - 05:33 AM
If the cylinder wall look good and is 100% rust free and free of any deep grooves you always have some very light scoring you maybe able to re-ring it after quick hone job.
Broken reed have nothing to do with it they just control the fuel-air mixture admitted to the cylinder. As the piston rises in the cylinder a vacuum is created in the crankcase beneath the piston. This vacuum opens the valve and admits the fuel-air mixture into the crankcase. As the piston descends, it raises the crankcase pressure causing the valve to close to retain the mixture and pressurize it for its eventual transfer through to the combustion chamber.
Just keep at your project sooner or later you get
The last project I did took just over years to rebiuld from the front to back that was Honda 300EX it was trash really bad when I got.
Posted 30 September 2011 - 05:39 AM
Posted 30 September 2011 - 06:46 AM
bronc3 said:
Reed valve is a simple effective form of check valve commonly fitted in the intake tract of the piston-controlled port. They allow asymmetric intake of the fuel charge, improving power and economy, while widening the power band.
Compression timing is very short usely start rigth around 280° before 0° TDC so it very small volume of compression and that why head have very small combustion chamber in order to boost compression ratio unlike a 4 stroke usely start rigth around 185° before 0° TDC which why the head have high volume combustion chamber and dish piston so don't end up with high compression ratio.
Posted 01 February 2012 - 10:41 AM
Posted 07 February 2012 - 06:19 PM
Posted 08 February 2012 - 08:57 PM
im getting new screws in the morning. and i have to find a way to make the pics smaller from my phone
Posted 14 February 2012 - 04:29 PM
Posted 14 February 2012 - 06:04 PM
Posted 15 February 2012 - 06:55 AM
korosys, on 14 February 2012 - 04:29 PM, said:
it wouldn't hurt to pull the clutch in and zip tie it like that while you are fooling with other stuff
Posted 15 February 2012 - 08:55 AM
Posted 20 February 2012 - 06:20 AM
Posted 01 March 2012 - 03:33 PM
Posted 03 March 2012 - 06:19 AM
Posted 06 March 2012 - 07:22 PM
oh and i drained the oil out and it looks like there was water in it so i think a case flush is needed
and she smokes a little hahahaha
Posted 07 March 2012 - 10:25 AM
You say you want another bike to work on, enduro or street, both have there merits, but a nice enduro can go any place you point it.
