FIRST POST! NEED HELP! 1998 YZ400f rattling and loss of power, now won't start???
4 replies to this topic
  • Warrix
Posted July 28, 2011 - 08:32 PM
Hey everybody first post here!
I just got my first 4-stroke hoping to be worry free for a while but no luck... I just wanna ride.
I got a 1998 yz400 had it for 2 weeks and then yesterday on the ride home it started "rattling" and would only "putt" home. I let it sit for a while then tried to start it but it had slightly less compression(still pretty stiff but I never had to use the lever) and never fired.
I took the entire bike apart to get to the top end, I finally got it all apart and the top end looks normal... No wear in the cylinder and the rings look fairly new with no visible damage. I also think it was punched out to 420cc because on the underside of the cylinder it was carved in "420-#32". I was looking at buying the kit myself.
Any ideas? Any info missing? Anything else I should check?
Thanks,
Dustin
  • primerib108
Posted July 29, 2011 - 06:28 AM
Did you check the timing? "Sometimes" you can jump a tooth from either a worn out cam chain or bad cam chain tensioner.....might as well check the sprockets for wear as well just in case the timing chain stretched.
Posted July 29, 2011 - 06:51 AM
Kind of late for that with the engine all apart.
  • zlathim
Posted July 29, 2011 - 07:23 AM
I agree.
To the OP. Next time, before tearing everything all apart, check the basics like engine compression (with a guage), valve timing, valve clearances, etc. It's kinda hard for us to help you because all we know is the bike stopped running, and now it is all tore apart.
  • Warrix
Posted July 30, 2011 - 12:16 PM
I'm used to 2 strokes so that's why I took it all apart before checking valves etc...
I took it in to the local shop an they said my timing chain is loose(everything was still apart though) He said I need a new cam chain and tensioner. He said the rings were fine. Then he quoted me $200 just to put it together if I supply the parts.
Is it hard to set the time? Or take the chain off?
Does this sound like he may be right?
Thanks,
Dustin
  • 5 replies
  • On January 15, 2017
  • Hot  47 replies
  • Hot  28 replies
  • Hot  30 replies
