Juice clutch?
3 replies to this topic
  • YZ_Abuser
Posted June 07, 2001 - 06:44 AM
Who is actually using the Hebo or Magura? Does it give enough throw to allow starting the bike in gear? The easier the pull, the shorter the throw.
My 250F is really finicky about have next to zero freeplay when starting in gear. If it's not adjusted just right it doesn't like starting in gear. Put a click or two on the adjuster and it will fire right up.
I've thought about going juice to a juice clutch, but have to make sure the bike will still start easily in gear. If i just MXed it'd be no problem. But the dead engine starts in XC/HS can make or break you.
Thanks for any info and sorry about the cross posting of the question.
YZ A
'96 YZ 125
'99 YZ 250
'01 YZ250F
  • racer629
Posted June 07, 2001 - 02:18 PM
I'm running a magura unit with an ARC foldable lever, and I can start my 426 in gear when hot. Your 250F should be no prob.
Mr. Wizard says: "Go BIG, or go home!"
  • ricky1
Posted June 07, 2001 - 02:47 PM
I had a Hebo on my '00 426, it was the first thing I put on my '01. Wouldn't ride without it.
Rick Fuller
'01 YZ426
'00 YZ426 destroyed by fire in desert race 4/22/01
'81 490 Maico
  • YZ_Abuser
Posted June 07, 2001 - 03:03 PM
It seems everyone loves their clutch, no matter the brand. The next question is who has the best prices on the Hebo and Magura juice clutches? What did it cost you guys?
Thanks again.
YZ A
'96 YZ 125
'99 YZ 250
'01 YZ250F
  • 9 replies
  • 0 replies
  • Hot  47 replies
  • Hot  36 replies
