02 426
4 replies to this topic
  • shelbyguy
Posted July 25, 2011 - 12:49 PM
basically 13.5:1 444
mild port work with both intake and exhaust hot-cams.
running the bike on the cart track downshifted 2 gears tipped it in and acted like it ran out of fuel...and wouldn't start again all day
got it home, tore it down chain skipped teeth on intake camshaft chain loose on cams with tensioner installed.
checked clearances cam/bucket everything within spec
gonna throw a new chain on it, is there an aftermarket manual adjuster, or is the "norm" to stick with the stocker?
thanks in advance
  • byggd
Posted July 25, 2011 - 02:08 PM
I have not heard of any problems with the OE auto adjuster. How may miles on the cam drive? May want to replace the chain guides if grooved deeply.
  • shelbyguy
Posted July 25, 2011 - 05:36 PM
ill check those tomorrow.
as it sits now i could install the OE adjuster without even pulling in the plunger,
cant imagine the chain had stretched that much??
gah, gonna completely gonna suck removing the head to do the guides
as for miles, really no clue as of right now.
will pull flywheel tomorrow and check out drive
  • byggd
Posted July 26, 2011 - 07:19 AM
It is possible. My son's KLR had a chain that streched that far. The new chain fixed it right up and made it much more quiet.
  • shelbyguy
Posted July 26, 2011 - 07:28 PM
sliders look near perfect.
the chain on the other hand looks terribad....like nearly half a link difference.
