2010/11 YZ450F questions
21 replies to this topic
  • YamaThumperRider
Posted July 21, 2011 - 08:57 PM
Im a fast B woods rider on a 09 YZ250F and its time for a new YZ450F. I have some questions about turning this into a woods weapon. With the new EFI can I adjust anything like the idle or the maps without the GYTR tuner? How harsh is the suspension, im 180 with gear and fairly aggressive in the woods. Can i get by without a revalve right away?
  • Eliass
Posted July 22, 2011 - 12:09 AM
First, the gearing needs to be changed due to the high speed first gear. Also it's alot easier to stall than the 2009 models so an trail flywheel is a must.
The suspension is very smooth in the initial stroke for mx which i like, i tried running swedish enduro and sure it's possible but not as comfortable as an enduro suspension.
Although your woods track can be very different with much higher speeds and less rock, i think that there are a thread about which mods to do to a 2010 yz450f for woods riding.
In worst case if you buy a stocker you can try without a revalve and then decide what to do.
  • thestuz
Posted July 22, 2011 - 03:14 AM
they are great stock for your weight. i weigh the same, and love my mates 10.
they stall, and they are snappy. but alover, a graet package.
  • tech24
Posted July 22, 2011 - 04:41 AM
A tuner is a must! You can only adjust idle speed without it but can't read what it is and its gotta be dead on. A flywheel and/or rekluse is a must. Very nice stock supsension even in the woods, worth a try at least. Injectioneering throttle body mod is recommended but not necessary.
  • YamaThumperRider
Posted July 22, 2011 - 06:48 AM
Thanks guys for the replies. So the tuner makes a huge difference and is a must?
  • Eliass
Posted July 22, 2011 - 07:07 AM
Some say that you can tune the bike better, expecially that you can tone down the bark off idle.
Some that have tried went back too the stock mapping because the bike didn't get any better. I haven't tried the tuner myself but i will too see for myself.
Rekluse is darn expensive but as the above posts it will make a ton of difference, makes it harder to stall the bike.
  • YamaThumperRider
Posted July 22, 2011 - 07:14 AM
Mmmm, I see, I definitely think this bike can be amazing in the woods, probably cheap about it too. Only thing I didn't like was the 270 some dollar tuner. But compared to buying an exhaust, it's not expensive at all.
Thanks for all re input again guys.
Zack
Posted July 22, 2011 - 07:23 AM
It wasn't that the people who returned to the stock map couldn't make the changes they wanted, it's just that they happened to like the stock map the best. There's a "woods map" in the map DB thread that a lot of guys like a lot.
Another thing that was a common compliant about the '10 model in the woods was the abrupt nature of the engine's off-idle response. Riders found that it was difficult to avoid a jerky, on/off feel when trying to use light throttle at low speeds. A company named Injectioneering was doing throttle body modifications that changed the throttle plate angle at idle to correct this, and the mod was getting good reviews. Haven't much about it in a while though. May have been corrected on the '11...don't know.
  • YamaThumperRider
Posted July 22, 2011 - 07:52 AM
I have read good things about the throttle body mods. Guess we'll see what I want to change when I actually get some ride time. I appreciate all the in-put gray
  • SurvivorMan
Posted July 22, 2011 - 08:14 AM
this bike is deadly in the woods once you get the right ECU map in place. You don't need to buy a tuner, someone around you has to have one and then just down load a woods type code. It will take you 5-10 minutes even if you enter your own code in manually. I have a code that makes the bottom super smooth with no hit and then just builds very linear to a great top end...no hits anywhere. the bike gets amazing traction on slippery roots with a burnt up 19' rear. Don't touch the exhaust, stock is fine. If you are an advanced level moto racer, then you will benefit from the upgraded exhaust, but stock works great. 49 tooth rear, hand guards and a skid plate. don't touch the valving, you are throwing away money unless you are a top pro on a work out program. Just set your sag with proper sized springs. The Rekluse helps but is not a must, just get a proper map into that ECU. You can detune this bike into a 400 XCW if you want to.
  • tech24
Posted July 22, 2011 - 09:43 AM
If you're trying to go inexpesive as possible I would say flywheel, borrowed tuner and let it eat. A nice slip on may be a good choice to as it really changes the power characteristics.
FWIW I use woods map, and GYTR broad powerband map mostly.
  • YamaThumperRider
Posted July 22, 2011 - 07:10 PM
The more you guys talk about it, the more I want it haha. I'll deff ask around to see if anyone has a tuner. I've been reading A LOT of stuff about this bike, all of it sounds very good.
  • cowboyona426
Posted July 25, 2011 - 08:31 AM
Sure wish I could find a bargain on a leftover 10 somewhere...
  • Troutman
Posted July 25, 2011 - 07:08 PM
Pick up a barely used one. There are some great barely used bikes for under $5000 around here. You will not regret it, it's a great bike and the same as the 2011, and 2012 and is still bullet-proof :smirk:
  • cowboyona426
Posted July 27, 2011 - 07:01 AM
I haven't been seeing anything locally. After seeing HRC's blacked out 11 with the Monster graphics I'm in love!
  • YamaLink
Posted July 27, 2011 - 10:20 AM
A gytr flywheel is a good option. I like that + a more aggressive map for woods riding.
  • Troutman
Posted July 27, 2011 - 07:27 PM
Yeah, that is a sweet bike. But keep an eye out I have seen more and more good bikes lately on Craigs list. One bad thing about the 2010, 11's, and 12's being the same bike is that I have not seen any really deep price cuts on the 10's or 11's that you would typically see with the introduction of newer updated models, good luck.
  • cowboyona426
Posted July 28, 2011 - 06:05 AM
Saw one on CL for $4500 in CO... that's a loooong way from WA though.
  • tech24
Posted July 28, 2011 - 07:50 AM
fly out and ride it back :smirk:
  • cowboyona426
Posted July 28, 2011 - 09:06 AM
BWAHAHAHA... don't give me any ideas!
  • Hot  47 replies
  • Hot  79 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
