Best possible forks
63 replies to this topic
  • Krannie McKranface
Posted July 17, 2011 - 06:16 PM
So, If I were rich, what forks from what bike would fit on the '07 WR450?
I see a lot of KX450 forks, YZ250f forks, etc on fleabay............
  • JDLowrance
Posted July 17, 2011 - 06:34 PM
Did you just win the lottery?
  • Birdy426
Posted July 17, 2011 - 09:56 PM
From what I read, the 06 and up YZ forks, the SSS ones, are supposed to be fantastic right out of the box.
  • MANIAC998
Posted July 18, 2011 - 03:39 AM
You'll probably laugh, but I'm gonna go with the Suzuki DRZ forks!!! For off-road riding/racing Conventional forks are incredible!!! They are soooooooo supple that it'll blow your mind! There buttery smooth!!! This of course, is AFTER revalving. Maniac
Posted July 18, 2011 - 12:48 PM
Yeah, but no.
They cannot handle whoops worth a darn.
You can re-valve any fork to be a supple as the DRZ series KYB forks, but then they will FAIL miserably in harsh high-speed terrain.
  • 123BigcoopDawg576
Posted July 18, 2011 - 01:36 PM
DaveJ's Phase 4 Kits and be done with it. :p :smirk: :(
  • SXP
Posted July 18, 2011 - 07:11 PM
I think he's been down that road......
  • MANIAC998
Posted July 18, 2011 - 07:49 PM
Krannie, I'm still going to disagree with some of your statement. There's just something about how "fluidly" conventional forks respond to trail junk compared to Inverted forks. Something that I don't believe you can ever achive with valving. That's how I feel. Your results may vary!!! Maniac
Posted July 18, 2011 - 08:25 PM
It doesn't matter if a fork is USD or RSU. It's all in the damping method.
You can have damping rod, open bath, cartridge, or dual cartridge with either.
The only reason modern forks are USD is because of structural rigidity and lower weight.
You can't take a Cadillac in the desert.
You can't take a Tank on the freeway.
They both do certain things very well.
They doesn't make one of them better.
If I can find a set of YZ SSS forks for the right price, I will try them.
I see no reason not to try the very best oem, within reason.
  • Baja trail Rider
Posted July 18, 2011 - 08:55 PM
Im with Manica,I run 87cr500 forks on my 07 450.There are no usd forks that ride like mine.There is no flex on usd forks thats what he is talking about.You cant take the jackhammer out of usd forks.Dont knock them if you dont know.It is not all in the damping.
  • bionic218
Posted July 18, 2011 - 09:03 PM
Best forks I ever had, hands down no question were the RSUs on my 1998 RM250.
The remainder of the motorcycle was a turd. Weak power, so-so components, cheap-azz hardware, etc.
But she would turn and burn (or at least turn and burp) and soak up anything you could throw at them. And because it was so underpowered it had to soak up a lot!
Great forks. The rest...eh...not so much.
  • MANIAC998
Posted July 19, 2011 - 03:42 AM
Thanks guys! That's what I was trying to say. It's amazing how there seems to be no stiction in Conventional forks, they just fluidly move thru there travel. Inverted's just seem to move in a "herky jerky" manner while going thru there travel. Didn't Honda use Conventional's on there Baja machine, the XR650rr? Maniac
  • GuyGraham
Posted July 19, 2011 - 04:10 AM
USD's are supposed to suffer from more stiction / friction due to stanchions becoming ever to slighty oval due to the bending moment being just below the slider, which is trying to slide into the slider
RWU forks bend just below the bottom yoke and hence don't suffer from this as the slider is 10 inches away!
Posted July 19, 2011 - 05:17 AM
Yes, where suppleness is irrelevant. Those forks can be set up for MONSTER hits without flexing the rest of the time.
Posted July 19, 2011 - 05:19 AM
Try '08+ KX450 forks sometime. Smooth as buttah. No stiction whatsoever.
Posted July 19, 2011 - 05:43 AM
http://cgi.ebay.com/...=item2c5df429dc
  • 123BigcoopDawg576
Posted July 19, 2011 - 05:45 AM
Look to beet up for my taste. Down side is once you buy those, you still have to valve and spring em.
Posted July 19, 2011 - 05:47 AM
Yeah, I know.
  • 123BigcoopDawg576
Posted July 19, 2011 - 06:54 AM
I take it you didnt like DaveJ's stuff the second go around?
  • Rot Box
Posted July 19, 2011 - 09:59 AM
Hmm I'm no expert, but I'm with the RSU guy's here. Maybe its the sprung weight that's easier to dampen/valve? I don't know. On the single track the 87 CR cartridge and the 96-98 Suzuki RM forks are pretty awesome. I have a set of 46mm RSU Blue Tube Paioli's that I'd like to try out as well, but they won't easily adapt to the WR or my CR I've already tried lol.
That said my favorite fork of all time is the 50mm WP Extremes that came on the late 90's KTM's and Bergs. Their trail manners are incredible--hands down the best forks I have ever ridden on by a long shot :smirk:
