Be careful how you route your vent hoses! BLAM!
6 replies to this topic
  • Krannie McKranface
Posted July 17, 2011 - 12:48 PM
Felt what only could be described as a 'champagne cork' sound and impact, against my left leg.
Huh, the Head cover gasket half-circle popped out of the Head cover, and hit my leg.
Turns out it actually 'ripped' right out of the one-piece head cover gasket.
Got the bike home, and checked: I had pinched the top end breather hose that goes to the air box. Pinched off completely by the subframe/airboot/carb. Before I tore it down, I opened the door to the airbox, and put my finger over the end of the tube, at the airbox entry point, with a rag tightly covering the blown out gasket piece. Little to no pressure at the tube's end with the motor running. Not good........
This is the vent hose that was pinched closed:
So, I ordered a new head cover gasket.
Who new?
So, the question is, do we need that 3-way vent hose junction near the carb, and the hoses attached, or can we just get away with the Head cover vent hose into the airbox? And shouldn't it run higher up in the box, if possible?
  • JDLowrance
Posted July 17, 2011 - 01:40 PM
I completely eliminated that quagmire of hoses. Buy a CC breather hose and 2 hose clamps from Yamaha for a 06-09 YZ450 (all the same). Install and plug airbox and starter ports with vaccum plugs sorced from your friendly neihborhood auto parts store.
John
Posted July 17, 2011 - 03:08 PM
John
:p:worthy::smirk:
  • 123BigcoopDawg576
Posted July 17, 2011 - 03:44 PM
John
Pics? Part Numbers?
  • OUTERLIMITS
Posted July 18, 2011 - 03:48 PM
Not sure about this. I modded mine so that there are two separate hoses, the one from the lower case (starter) and the one from the top of the valve cover, both capped with uni filters. The lower one I thought about capping as well, thinking it was only an oil return to the starter, but it was definitely "pulsing" when the engine was running just like the other one so I decided not to. Ultimately, I plan to eliminate that filter (under the tank) and tie back into the hose running off the valve cover, which is routed up.
  • kawi380
Posted July 19, 2011 - 02:43 PM
John
Exactly what I did and works great?:smirk:
Posted July 19, 2011 - 05:06 PM
FIXED IT
But haven't cleaned it up yet........
