2010 not staying in neutral
9 replies to this topic
  • tydock88
Posted July 15, 2011 - 12:46 PM
Hi everyone,
My 2010 yz450f is really picky about getting into neutral and if I let the tire roll at all it slips into gear, anyone else have this issue?
I thought it was just because it was new but now im at about 25 hours.
Thanks
  • delmas
Posted July 15, 2011 - 02:08 PM
no not ever
  • 2000 xr650r
Posted July 17, 2011 - 08:39 AM
Dont dry rap the bike, it might take you for a unexpected ride.
  • tech24
Posted July 17, 2011 - 04:24 PM
This only happens when its not completely in N. It is hard as are other bikes to find N unless the engine is off (except when riding and shifting to second :smirk: )
  • tydock88
Posted July 17, 2011 - 08:18 PM
Thanks for your replies, it sometimes doesn't like to stay in neutral when rolling it down my driveway to load it up, it will roll about 3 feet pop into gear then I have to stop and find it again or pull in the clutch.
  • rickallen124
Posted July 17, 2011 - 08:30 PM
I'd try to find someone at the track that has the same bike and have them check it out. Does it ever come out of any of the other gears?
Posted July 18, 2011 - 06:58 AM
If the trans otherwise works well, inspect the shift segment ("star wheel") behind the clutch. There should be a small notch for the stopper lever (indexing arm) roller to engage in when it's in neutral, and the roller should be fairly willing to stay there.
  • brentn
Posted July 18, 2011 - 05:01 PM
Check the bolt that holds the stopper make sure it's secure.
2010/11's have neutral finding issues, but it's definitely not normal for the bike to be in neutral and then pop into gear when rolling.
  • tydock88
Posted July 19, 2011 - 06:29 AM
Thanks for your suggestions, I will check it out next time I change my oil. Would I be able to find what the location of this bolt in the manual?
Posted July 19, 2011 - 07:30 AM
Yes. It's #8 here:
Showing it with the shift cam and forks makes it appear to be inside the crankcase, but it's actually right behind the clutch with the shift linkage.
  • 0 replies
  • 10 replies
  • Hot  38 replies
  • Hot  113 replies
  • Hot  50 replies
