stk exhaust cone removal 09 yz540f
13 replies to this topic
  • mgrych
Posted July 14, 2011 - 04:56 PM
Need some directions or pictures on removing the "2 cones" from the stock exhaust to give it a little deeper sound, and a bit more power
  • NE14MX
Posted July 15, 2011 - 04:44 AM
The problem with doing that is the header is too large of a diameter for a regular type flow through muffler. You will get less power and a lot more noise.
  • crf450319
Posted July 15, 2011 - 05:55 AM
That seems to be something that's up for debate, some guys here swear that by removing the cone attached to the endcap they're getting more power out of the bike. Someone could agrue that if you only lose power, then mounting up an aftermarket slip-on to the stock header won't get you any more power either. Which is completely false.
My buddy just installed one of these Lexx slip-ons onto his new '09 yz450f and he's very happy with it ($179 shipped) :
http://cgi.ebay.com/...sQ5fAccessories
Read these :
http://www.thumperta...ad.php?t=851003
http://www.thumperta...&highlight=cone
Pics :
  • mgrych
Posted July 15, 2011 - 06:09 AM
It sounds like it has some advantages, but i do understand what your saying about the theory behind it.
I've decided to do it, if i notice a drop in power, then slip on it is. My question now is once i drill out both sets of rivets, Am I supposed to remove both cones, or both cones and that perforated tube? THat second link you sent me has a great picture on the second page but doesn't go into the best detail about what is done.
Posted July 15, 2011 - 06:53 AM
It will be louder, but you misunderstand the power issue vs. header diameter. Removing the cones will give you an immediate boost in mid range (~5K) power. Because the header is oversize, the power increase could be greater if the right sized header tubing were used.
  • mgrych
Posted July 15, 2011 - 08:39 AM
So.... is this the way to go?
  • crf450319
Posted July 15, 2011 - 09:54 AM
If I were interested in doing the mod, I'd remove the end cap and I'd cut the tube/perforated tapered end off.
  • mgrych
Posted July 15, 2011 - 01:42 PM
drilled out the rivets, how do u get that sealant off? i mean how do you separate the endcap from the rest with the sealant holding it in place? razor?
  • ttr250dude
Posted July 16, 2011 - 04:14 PM
With a big hammer, preferably a heavy rubber mallet. When i took mine out i had to keep hitting it from side to side. It takes a while, but thats how some of other guys on TT do it. I dont think there's any other way of doing it.
Yes, use a razor to slice the black sealant. I think its silicone.
  • mgrych
Posted July 16, 2011 - 04:18 PM
ok, got that done it was a pain in the @$$, but its all out now... too bad I stripped the oil drain plug now... F me..
  • ttr250dude
Posted July 16, 2011 - 04:31 PM
Now would be a good time to replace the muffler packing while you have the muffler apart. BTW, where in WI are you?
  • mgrych
Posted July 17, 2011 - 08:00 AM
GB, i already put her back together
  • 92db
Posted July 17, 2011 - 08:52 AM
Good call.
It is better now than a couple of years ago but there obviously still people out there that don't yet understand the performance gains that come from a fresh repack not to mention the accompanying db reduction.
  • mgrych
Posted July 18, 2011 - 06:26 AM
forgot to mention my bike is brand new, the packing was still all white
  • On January 15, 2017
  • 10 replies
  • Hot  38 replies
  • Hot  30 replies
