XR100 Headlight hook-up
8 replies to this topic
  • motoxracer30
Posted July 14, 2011 - 04:39 PM
Hi everyone,
I hope this fits under this thread, but i have a few questions on parts and what all they come with and what all ill need wiring wise and installation in general.
I have a 2000 XR100R that i want to put a headlight on. I know I am going to need a new stator and obviously the headlight kit. However, the kit doesnt say if it comes with wires. or if i will need anything else for it to hookup and function correctly.
here is links to the stator and the headlight kit i plan on using. (if you know of better ones to use, please help me out)
http://www.acerbis.c...&id_categoria=6
http://www.procycle....f100-xr100.html
(the stator is at the very bottom of the page)
so will i need to buy anything else or can i just buy these two things and it work out? thanks!
  • ickfinger
Posted July 15, 2011 - 03:04 PM
i think you need a regulator, you should get in touch with ricky stator, think he has a lot of experience with this
  • JmE
Posted July 15, 2011 - 04:40 PM
Based upon the limited information on the two website links...
I'd figure that you'll need some wire, a switch, proper connectors (two of those female bullet type for the stator connector and whatever kind you need for the light and switch), and a regulator (unless there is one included with the light).
A replacement gasket for the stator side engine cover is possible as well. I haven't put a new gasket on as of yet but probably will eventually.
That's all I can think of.
A quick email to the headlight supplier would tell you if it comes with a regulator, switch, harness, and connectors. My guess is that it probably doesn't but it's only a guess.
  • theraymondguy
Posted July 15, 2011 - 04:58 PM
Uh, no.
Won't need a regulator if the bulb voltage is matched to the stator correctly; How many Z50A's did Honda sell from 1969 to 1978 with no regulator? A bunch I'd bet, not to mention the XR200R's, 250R's, 350R's and so forth and so on / not to mention that all honda's mini bikes that were road legal all used power direct from the stator to run the headlight.
A regulator will help to extend bulb life if you do like to hold the bike on rev limiter for extended periods while in neutral, otherwise... it's unnecessary.
  • JmE
Posted July 15, 2011 - 05:09 PM
I accidentally didn't hook up my regulator and was testing out my install. One element of my halogen bulb promptly burned out. I was nowhere near a 'rev limit' (As far as I've read, the CRF 100 CDI does NOT have a limiter)
If the revs are low, you probably don't need one. However, I found out rather quickly that it was simpler to just use a regulator.
It's an individual choice, however, a regulator makes good sense to me.
  • theraymondguy
Posted July 15, 2011 - 05:21 PM
I don't disagree with you JmE, clearly though there is some mismatch between your stator output and bulb voltage. In your case a regulator is a must. Yes, the stock CDI does have a rev limiter (not that you'd ever want to hit it, there's no power advantage with a stock / mildly modified engine).
  • JmE
Posted July 15, 2011 - 08:23 PM
You're probably correct, theraymondguy. It's all good. :smirk:
Without a battery, I couldn't imagine myself trying to load balance the turn signals, rear lights, horn, and headlight (all except horn and one set of turn signals were on during the incident). I always thought that older bikes without regulators used the lights to limit the current to individual bulbs (and to the battery, if so equipped). Also, when a bulb goes out, isn't their a risk of overloading the other bulbs (and battery if it has one)? On the surface, balancing such a system seems beyond my abilities so that's why I use a regulator.
Are there any major drawbacks to using a regulator? If there are, it may behoove me to consider load balancing.
*** Side note: I was using the same stator that the OP is looking to purchase and a Baja Designs headlight so the bulb to stator mismatch is likely to be similar for the OP. ***
BTW: I'm truly not arguing the point. My knowledge is minimal... I really want to know in case it might be better to lose my regulator. More importantly, it may also help the OP decide.
  • socalxr
Posted July 15, 2011 - 10:10 PM
Check out Baja Designs. They have everything, that's what I run.
  • theraymondguy
Posted July 16, 2011 - 05:42 AM
Ah, only the headlamp and rear running light was powered directly by the stator, everything else (horn, turn signals, brake) was powered by a regulator / rectifier, 6 or 12V. You're 100% correct, it would be ineffective to try and balance a full system.
CR 230F Making it Street Legal with the best Speedometer by crfer2
  • Hot  35 replies
Front brakes don't work by Willyamaha
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • Hot  30 replies
1993 Honda XR200R bearings kit/list by Jmechler192
  • 0 replies
Honda CRF100F 2017 by Chris.GVS
Honda CRF100F 2017
  • 0 reviews
4-stroke 250, or 2-stroke 125? by ThatOneRider
  • Hot  29 replies
