Sprocket shaft seal.
3 replies to this topic
  • gildnernorth101
Posted July 12, 2011 - 05:33 PM
2006 yz 450. The case doesnt have to be split to replace this seal like on the 2 strokes does it?
  • MANIAC998
Posted July 13, 2011 - 03:58 AM
Not on my '06 WR anyhow. I just did mine last weekend. Pull the countershaft sprocket, remove two bolts & the spacer, and pull the seal. Replace the seal along with the o-ring inside the spacer and your leak should be fixed. Maniac
  • GCannon
Posted July 13, 2011 - 08:12 AM
Make sure your tranny bearing is good. if your chain has been run too tight it could have an issue.
  • gildnernorth101
Posted July 14, 2011 - 05:29 PM
Thanks guys
