2004 wr450 lighting problem
No replies to this topic
  • krakaphat
Posted July 11, 2011 - 07:20 PM
Hello guys
Not sure if i have the right spot but here goes, i have a 2004 wr 450 and i have an issue with the headlight when idling the headlight works but a little dim, it brightens up when revved however at idle with the headlight on the indicators dont work but with headlight off they do work.
Also when indicators are on when turning a corner and i give it open throttle and take it to high revs the indicator globes blow.
Does this sound like a rectifier problem, i have heard that the headlight runs off ac power, is this the same for the indicators too, i am only running dc globes could that be my problem, im not even sure you can get a H4 a/c globe.
