426f question
5 replies to this topic
  • Stinger1133
Posted July 10, 2011 - 07:58 AM
I just bought a 2000 yz426f. I remember seeing on here somewhere a thread for putting the 426f engine in an aluminum frame a long time ago. Does anyone know if this thread still exists ? I have searched everywhere but can not find it. I have my bike stripped down and want to buy an aluminum frame on fleabay. Thanks.
Posted July 10, 2011 - 08:18 AM
It's a lot of work, and you'd need to use a wet sump kit for the engine (which I adamantly recommend against doing) or build an external oil tank, just for starters. You can save as much weight by using a frame from an '03-'05 YZ450 and have fewer problems to work out.
  • Stinger1133
Posted July 10, 2011 - 08:21 AM
I didnt know that would work. That sounds good. This is my first 4stroke and got a really good deal on it but it needs work. Engine runs really strong and transmission shifts really smooth. I will look into the 450 frames and see what I can find. Thanks.
  • QuietFlight
Posted July 10, 2011 - 08:30 AM
but it needs work. Engine runs really strong and transmission shifts really smooth..
how much work could it need?
  • Stinger1133
Posted July 10, 2011 - 08:57 AM
On the bottom of the engine the oil drain plug is cracked and has been jb welded. The rear shock is shot and leaking oil everywhere. The front forks are for a 250lbs rider I think because they are really stiff. the rear wheel spokes are all loose and the wheel wobles. Thats really about it. I am thinking of getting a set of good used cases from ebay and fixing the cracked plug issue. I am going to get the rear shock redone. The front forks I can do here. As for the wheels, I will probably get new ones. I will post some pics of the cracked part of the engine.
  • Stinger1133
Posted July 10, 2011 - 09:12 AM
Here is a pic of the cracked case that has been jb welded.
  • 9 replies
  • 0 replies
  • Hot  36 replies
