Tools needed to change for seals 06 yz450f
7 replies to this topic
  • Randal McSandal
Posted July 07, 2011 - 11:28 AM
I'm pretty mechanically inclined but this will be a learning experience..
I have all the basic tools needed to complete most jobs. What exactly will I need to make this a pain free process?
Thanks
Posted July 07, 2011 - 11:52 AM
Fork seals, I'm guessing? You need to read the manual enough times to make sense of it. Frankly, that can take quite a while. These two posts should help:
http://www.thumperta...814#post8762814
http://www.thumperta...008#post8002008
As far as tools go, you need a 49mm octagon ring wrench to unscrew the cartridge from the top of the fork tube, a 32mm octagon wrench adapter to remove the base valve from the cartridge (not required if not changing the cartridge oil or servicing any of the damping components), a damper rod holder (which is built into some cap ring wrenches, and can be a simple piece of metal strap with a 12mm x 30mm slot cut in it), and a seal driver.
It's not a hard fork to work on at all.
  • Randal McSandal
Posted July 07, 2011 - 12:41 PM
Sorry I forgot to include fork seal in the description :thumbsup:
Thanks for your help! I will try to get my hands on these tools and get it done.
  • crf450319
Posted July 07, 2011 - 04:36 PM
It's not hard to do, buy a Tusk dual chamber fork cap wrench ($20) :
http://www.rockymoun...dFamilyId=17693
A fork seal bullet ($6) :
http://www.rockymoun...dFamilyId=13987
A fork seal driver ($40)
http://www.rockymoun...odFamilyId=1479
Then watch these videos :
The 3 tools you need will more than pay for themselves the first time you use them. Take your time & have fun learning !
Posted July 07, 2011 - 05:52 PM
Handy, but the bag the seals come in, or a simple piece of common cellophane wrap from the kitchen works about as well for nothing.
  • Jonbikes
Posted July 07, 2011 - 06:10 PM
If you are just doing seals and not touching the damper then there is no need to take the top end of the fork apart. You will only need a fork seal driver, something to hold the damper rod (I actually just used a 14mm box end wrench, or a wrench in and around that size, could have been a bit bigger), and then whatever is required on that particular year fork to get the bottom of the leg apart.
Last time I did the fork seals on my 07 yz450 it probably took me 20 minutes or less. The only thing I regret not having was a seal bullet and the inginuity to use something in its place. I ended up CAREFULLY sliding the seals down over the shoulder on the inner leg with the help of some seal friendly grease, problem free.
EDIT- fork seal driver, absolute must have.
  • RiderX
Posted July 08, 2011 - 06:32 AM
I made my own fork seal driver out of a PVC adapter that was the diameter of a fork seal on the small end and much larger on the other end for something to grab or tap on. I split it in half and used duct tape on one end as a hinge, lol. It works, but a metal one with pins that hold the halves together works better (I have one of these as well).
:thumbsup:
  • crf450319
Posted July 08, 2011 - 08:16 AM
True enough, I service my suspension front & back every 20 hours of ride time. I've had 1 fork seal leak on me in 89 hours of runtime, actually it's leaking now but I'm one hour of ride time away from doing a complete service so it'll wait. I won't pull a fork apart unless I'm going to change the oil in the inner chamber, should've mentioned that..
:thumbsup:
Yes, I've done that before. But I like the idea of having a thin layer of hard plastic between the seal and edge(s) of the tube. The bullet isn't a necessity, but for $6 I'll use it as opposed to a bag.
  • On January 15, 2017
  • Hot  47 replies
  • Hot  28 replies
  • Hot  113 replies
  • 3 replies
