2009 yz450f Stopped Running.....
9 replies to this topic
  • Themackattack
Posted July 06, 2011 - 02:47 PM
I was riding my bike on saturday and it ran fine, went out to use it sunday and nothing... Kicks over fine, and back fires occasonaly. It would start up if i bumped started it down a hill and would run ok but wouldnt idle.
So i changed the air filter, and put in a new plug.
I am stumped on what to do next
If anyone has any info or help please feel free to chim in!
Thanks
  • blakers213
Posted July 06, 2011 - 05:37 PM
I'd start with the carb. Check the jets, see if any are clogged.
  • Themackattack
Posted July 06, 2011 - 07:01 PM
alright, ill take the carb apart and take out the jets and clean em up. Anything else in mind if that dosnt work?
  • Themackattack
Posted July 07, 2011 - 02:50 PM
Cleaned out the carb and same thing, backfired on the first kick then nothing after that......
Any more suggestions? I herd something about the timming chain maybe? How do i adjust that
  • dvn
Posted July 07, 2011 - 04:02 PM
Did you remove the pilot jet and clean it or better yet, replace it? If it runs fine other than idle, I don't think it jumped time. Why don't you pull the valve cover and check? I'm still betting a dirty pilot.
  • Themackattack
Posted July 07, 2011 - 04:19 PM
i did clean the pilot jet and everything looked clean. How do i check the timing?
Posted July 07, 2011 - 05:54 PM
You're saying you don't have a manual?
http://www.yamaha-mo...uals/index.aspx
http://www.yamahaown...ook.com.au/?r=0
  • stevenb28
Posted July 09, 2011 - 03:25 AM
Thats valves way out of spec, can almost guarantee it. I had the same problem.
  • Themackattack
Posted July 11, 2011 - 03:18 PM
i checked the timing chain and valves and everything is in spec.
I am thinking that it might be the magneto not produceing enough spark to start it as it is back firing and will start if i push it down the hill.
I put fresh gas in it also now.
Anyone else thinkin of what it could be?
Posted July 11, 2011 - 04:49 PM
Verify that TDC as indicated by the flywheel is really TDC at the piston.
  • Hot  113 replies
  • Hot  50 replies
  • 0 replies
  • On January 15, 2017
