My header heated up to 536 degrees in 5 minutes.. ***??
14 replies to this topic
  • SOCAL90
Posted July 01, 2011 - 08:38 PM
Hello everyone.. I need some help.
Any of you have a clue why my head pipe would get so hot that it started cooking my carbon heat guard in about 5 minutes? I checked the temp and it was 536 degrees!
My set up is: 08 yz450..Akra evo full system, JD Jet kit.. stock motor
The bike has been sitting for about a year (had back surgery) and the ONLY thing wrong with it is the Akra can is a little bent due to a crash I had last year.
When the header was over 500 degrees the can only tested at 170, the cylinder head was about the same..
Any ideas? :thumbsup:
  • gscx
Posted July 01, 2011 - 08:47 PM
Thats it? I thought they got alot hotter than that
  • woods-rider
Posted July 01, 2011 - 08:50 PM
When motors are lean they can run hot. Try richening it up a bit.
  • gscx
Posted July 01, 2011 - 08:52 PM
If its running fine then there isnt any need for it. They will get so hot they glow if you let them sit and idle
  • SOCAL90
Posted July 01, 2011 - 09:32 PM
I've never had my carbon literally burn and smoke.. it bubbled the akra logo right off..
I will check how lean it is though, thanks
  • ttr250dude
Posted July 01, 2011 - 10:43 PM
:thumbsup: :ride: nice
No offense but, use the search button. DO NOT richen your A/F ratio if your bike runs good. That will not solve the problem. The problem is that you let it sit and idle for 5 minutes.. If you let these bikes sit for more than 1 minute the header starts glowing red. These bikes need air flow. If your bike is already at running temp dont let it sit and run for more than 1 minute or else it will start heating up alot. They are known to over heat even when in slow 1st gear single track.
Posted July 02, 2011 - 06:52 AM
They do. Red heat visible in twilight is around 880.
More often than not, a rich idle will make the header hot faster than a lean one, and you can't expect the bike to sit and idle for 5 minutes. That becomes a race to see whether the radiator will boil over before the header turns orange.
Revving the engine frequently to pump cold air through the system will reduce the effect, but it's better just to keep moving.
  • Gunner354
Posted July 02, 2011 - 07:02 AM
This is not only wrong but very bad advise.
  • RiderX
Posted July 02, 2011 - 07:32 AM
Not necessarily.
  • Gunner354
Posted July 02, 2011 - 08:34 AM
Not necessarily.
Really? Please explain with solid facts.
  • RiderX
Posted July 02, 2011 - 09:42 AM
A lean fuel mixture can cause higher combustion temps and EGT's.
  • Gunner354
Posted July 02, 2011 - 10:20 AM
Let's get back on track here. Suggesting richening up jetting based on a presumed lean condition due to a presumed abnormal exhaust pipe temp is just beyond me and very bad advise.
  • SOCAL90
Posted July 03, 2011 - 12:45 PM
Thanks everyone for the reply's... I guess I should have mentioned that I didn't let it idle for 5 minutes. I used the choke on idle until I could turn it off, then I blipped the throttle a number of times (I am under the impression that the water pump only spins if the motor is revving.. is that correct?) I started to see smoke coming off of the header, which I assumed was probably just dust burning off or something. But, the smoke increased rapidly. That was when I realized it was the carbon fiber heat guard that was actually burning. Which made me check the temp because that has never happened and I assumed it was too hot if the "heat guard" was literally melting. That's where my main concern came from. Do you think maybe the carbon has deteriorated or something and that's why it started to burn?
Posted July 03, 2011 - 01:37 PM
No. It's geared to the engine, so if one turns, so does the other. They don't move very much water at an idle, though. Then again, the radiators don't do much without air flowing over them anyway.
  • ttr250dude
Posted July 03, 2011 - 03:02 PM
What we're trying to say is that you shouldnt let the bike sit stationary with the engine running for that long. It doesnt matter if you let it idle or blip the throttle. The problem is that air is not passing through the radiators. The only reason cars can sit and idle for a long time is because of the fans that pull air through the radiator when the coolant reaches a certain temp.
  • 10 replies
  • On January 15, 2017
