Can I reduce wieght 2004 yz450f?
16 replies to this topic
  • Orlandorider
Posted July 01, 2011 - 09:02 AM
I was wondering if anyone can give me some ideas for reducing the weight of my 2004 yz450f. Some have told me to get aluminum hubs to reduce 5 lbs.
  • RiderX
Posted July 01, 2011 - 09:31 AM
A few things that come to mind are light weight wheels (hubs, spokes, and rims), light weight tubes, light weight axles, light weight exhaust, (Ti), Ti bolts, triple clamps.
This is mostly very expensive stuff. You'd probably lose more weight for less by purchasing a newer YZ.
Posted July 01, 2011 - 02:21 PM
The bike has aluminum hubs already. Dropping significant amounts of weight from the late MX bikes is neither easy nor cheap, as they just aren't packed with excess fat anymore.
  • ttr250dude
Posted July 01, 2011 - 11:05 PM
Like gray said, trying to remove alot of weight on these bikes is gonna cost big bucks. But, if you're on a budget i would get a lighter muffler. Since the muffler is higher up on the bike it will be more noticeable when tossing the bike around. Not sure if i worded that last part correctly...
Edited by ttr250dude, July 03, 2011 - 01:55 AM.
  • mikedabike
Posted July 02, 2011 - 04:24 AM
The newer YZ's are not any lighter than a 04. If anything the 10/11 gained weight. They do feel lighter when riding due to better mass centralization.
  • dalonar
Posted July 02, 2011 - 05:25 AM
jump on the treadmill!
  • Orlandorider
Posted July 05, 2011 - 08:28 AM
Been working the body and lost 12 and got stronger. Getting stronger was the bigger thing.....
  • Orlandorider
Posted July 05, 2011 - 08:32 AM
Thought the hubs were cast that, at least that is what someone said. Seems like they should have been machined for balance.
Posted July 05, 2011 - 11:17 AM
The hubs are in fact cast. So what? Doesn't mean they aren't light. As far as balance goes, because of the relatively small diameter, an 8 ounce imbalance at the hub will have less effect than one ounce at the tire, and you don't balance your wheels anyway, do you?
  • kieethes
Posted July 05, 2011 - 11:22 AM
Machined hubs are stronger, but the weight is fairly similar. I would recommend working out, like others said, and devoting a part of each ride to slow speed balance and precision. Doing this stuff gets your body in tune with your bike, so you can work together.
  • bryawn
Posted July 06, 2011 - 10:08 PM
I recently picked up an '04 YZ450F and while it is somewhat heavier than my YZ250 smoker, the strong power more than makes up for the few extra pounds. People told me also that the 4Ts don't turn and I've been riding it in the woods, GP races and open areas and it's just a lot of fun. My only complaint is the MX suspension, which is too stiff for the stuff I ride for the most part.
I would worry more about dialing in the boingers and not worry about the weight. That is certainly the next thing on my list.
  • PawleeP
Posted December 30, 2011 - 06:06 AM
anyone know what can be done to make a 2004 yz 450f a little less top heavy and maybe handle more like a 2006+ model.. shaving weight from upper part of frame?.. P
Edited by PawleeP, December 30, 2011 - 06:08 AM.
typo
  • motorboy1128
Posted December 30, 2011 - 10:26 AM
one big thing is.....the amount of gas in your tank maybe rn it half ful instead of completely full....run ligher tires.....remove the stock exhaust put a ti on there.....aluinum and ti are your friends.....but theres not light abut 450's get a 250 2 stroke.
  • scrubbin627
Posted December 30, 2011 - 03:28 PM
DO NOT try shave weight from your frame. There isnt really a cheap way to cut weight from a motocross bike other than carbon fiber and titanium...$$. Make sure your suspension is working properly, it has made a big difference on my 04.
  • PawleeP
Posted December 31, 2011 - 05:52 AM
Thanx MotorBoy and everyone else for the insight... may just wait for some more bux and look for a 2006 or newer 450f:p
and by the way does anyone know the benefits of upgrading the triple clamps
on a 2004 YZ450?
O:banghead: One of the ones I am researching has a pro-Pilot shock set-up and some high tech alloy triple clamps (applied triple clamp) which are allegedly 300-400 new along with a white bros exhaust
Edited by PawleeP, December 31, 2011 - 06:18 AM.
additional question(s)
  • PawleeP
Posted December 31, 2011 - 06:22 AM
thanx srubbin.. was thinking if I could shave some of the weight from upper extremities, of an03-04 yz450f it may handle as well or better than a 2006-09.. any thought from someone that has ridden both?
  • Orlandorider
Posted January 05, 2012 - 09:57 AM
Good Replys, I have been working on my own weight and strength, the gear I wear and keeping the bike working in top shape. I think being strong makes the bike feel lighter. I dropped 25 lbs and the endurance is way up. I would love to see how light a KTM 350 is but the difference between a YZ250 and 450 still seems like a lot. Maybe the best combo is a modified 250 (285cc) lighter but with more power.
