Interesting Problem (WR 450 Help)
3 replies to this topic
  • jswr450
Posted June 30, 2011 - 08:04 PM
Hi Everyone,
So I just got done checking the valves on my 08 WR450. In that past I've paid people to do the valves and this time I decided to do it myself. I noticed that someone before me started to strip one of the bolts on the air induction pipe where it bolts into the cylinder head just above the exhaust header.
I was able to get one of the bolts to torque up, but the other (near the radiator hose) is only snug, and I can tell that it's not going to torque. This looks like a pain to helicoil if needed, and I'm hoping that it won't be too much of an issue to leave it. When I got the bike I had the dealer plug that port as part of the smog removal so instead of a gasket there's a metal spacer. Is this pressurized with exhaust? I want to make sure I can't suck dirt in...
It's part 1, 2 (metal spacer), and the bolt in question is #3 in this diagram:
http://shop.thumpert...008&model=12928
I know this is a weird problem, but any help would be appreciated. Thanks guys!!
  • JDLowrance
Posted June 30, 2011 - 09:17 PM
Remove the AIS and plug the hole with the GYT-R AIS removal kit. That way you will never have the problem again.
Sorted.
  • davidl9999
Posted June 30, 2011 - 09:22 PM
:thumbsup: What he said.
The right way to fix that bolt hole is to helicoil or timesert it, unless you just avoid the problem altogether.
  • jswr450
Posted June 30, 2011 - 09:53 PM
Thank you for the replies.
How does the kit plug the hole (do I still need to use that bolt)? I already have the plate that blocks off the passageway, but it just looks like the ais is still hooked up. That's the way the dealer installed the kit when I got the bike...
Thanks again for the help on this unusual, unfortunate problem...
