Loose flywheel, yz450
3 replies to this topic
  • bykas
Posted June 30, 2011 - 02:50 PM
Im replacing my cam chain for the 1st time on this bike, 06 yz450 cause it started to make a noise when reving up in the chain area. Bike still ran great, valves are in spec.....When I got to the flywheel gave it a little tug before putting on the puller and it slipped right off. Fits tight when all the way on, just slips on and off easy. Do I have a problem here??? Any help would be appreciated.
  • bykas
Posted June 30, 2011 - 03:04 PM
Just put the flywheel back on and tightened it up with Impact, now the puller is needed to take it off...Could it have loosened up, maybe the noise I was hearing???
  • RiderX
Posted June 30, 2011 - 06:22 PM
It's very possible. Did you inspect the mating surfaces? If they don't looked marred up you may have caught it before any real damage was done. As long as it fits tight and there is no play at all you're fine. I would put a drop of loc-tite on that nut.
  • bykas
Posted June 30, 2011 - 08:11 PM
Thats what I'm thinking. It was the last ride, just started hearing the noise, turned back to camp and shut her down. Hopefuly I got lucky....Surfaces look good, tightened it up with red thread lock.
  • 10 replies
  • 0 replies
  • 5 replies
  • Hot  36 replies
  • Hot  30 replies
