Low footpegs on 2010/ 11 yzf? (non protaper)
10 replies to this topic
  • Quernix
Posted June 30, 2011 - 11:14 AM
Is there a solution other than the pro taper pegs to lower the footpegs on the 2010/11 fs out there, yet?
Do the STR brackets of the -09 models fit?
  • Anssi
Posted June 30, 2011 - 11:21 AM
Fastway footpegs in the lowboy position:
http://www.promotobi...Path/23_100_113
  • Quernix
Posted June 30, 2011 - 11:24 AM
Unfortunately they don't list the lowboy brackets for the 2010/11 models. Can I use the OEM brackets for the lowboy position?
  • Anssi
Posted June 30, 2011 - 01:42 PM
I'm 99% sure that they will mount in the Lowboy position using the stock brackets. I will check this weekend (my dad has a pair on his 2010 YZ450F).
  • norcal_hoss
Posted June 30, 2011 - 03:52 PM
I have the fastway low boy pegs on my 2011 and they came off my 2010 they definitely fit.
  • ccie2be
Posted June 30, 2011 - 05:59 PM
I just got an 11. You can cut the barrel off the bottom of the stock footpeg and move it to the top and it will lower it down and back about 1/2 In.
  • Troutman
Posted June 30, 2011 - 07:35 PM
+2, Cut the stockers and put the barrel on the bottom it works and its free. The stock pegs on the 2010-12 are nice and wide so you don't get any advantage of buying an aftermarket wider lower peg, just a lighter wallet :thumbsup:
  • Quernix
Posted July 02, 2011 - 01:08 AM
The stock pegs hit a stop on the bracket. Just cutting off the barrel would not work. One had to turn the brackets as well...don't think this will work.
The fastway pegs have an adjustable stop, do tehy?
  • eazrider
Posted July 02, 2011 - 07:28 AM
Switched my brackets left to right on my '10, may have had to grind something or other (can't remember, it's been a year now) the result was positioning the pegs slightly farther back, and lower, works for me....
  • Troutman
Posted July 03, 2011 - 10:22 AM
It works, but you might have to grind the stop like said above. My buddy did it and it worked great I will ask him what he had to do.
  • ccie2be
Posted July 06, 2011 - 04:59 PM
yep,i checked the bracket and it'll work. Looks the same as the older ones.
  • Hot  47 replies
  • 5 replies
  • Hot  50 replies
  • Hot  113 replies
  • On January 15, 2017
