Hi guys, I'm new on TT. I'd appreciate any helpful advice. Sorry for the novel but I think the better I explain, the better you can help me.
Bought a 2004 crf250x 3 months ago. After supposedly seizing the top-end, the owner had it rebuilt, and has the cyl. head from a 250r, re-jetted carb, FMF Powerbomb header and Powercore 4 spark arrester muffler. Other than that, the bike is stock and in great shape. Went trail riding in late April (about 7 hours), bike started easily all day and ran great with awesome power. Next morning - no start. Cleaned out the fuel tank, carb and installed new spark plug, no luck. Two weeks later, a buddy and I got it started after about 30 kicks (no luck with e-start), and the bike ran the trails flawlessly all day (rode about 4 hours) and would restart easily with kick or electric if the engine was still warm. Same issue next day (many kicks to start, then ran great for 5 hours of trails, no loss in power). Took it to the Honda shop, valves were tight and needed shims. They adjusted valves to correct clearance and went thru the carb just in case, also installed decompressor that was apparently missing from my camshaft - STILL no start. They say a compression test shows only 25 psi and leakdown test shows it's not leaking past the valves, but possibly piston or rings.
My question - considering how well the bike ran last time I rode it (once I got it started), could the compression really be that low? I would think with only 25 psi, it would barely idle. Like I said, 2 days in a row it ran perfectly all day after the complicated start. No stalls, odd noises, smells, or loss of engine power and it hasn't lost any oil. I would think if the piston or rings wore out as I was riding, I would have noticed something. Could there still be an issue with the valves or valve seats, even after they shimmed them? Could the timing chain have jumped a tooth, making starting impossible but okay enough to run warm? I would think the shop would notice that with the valve cover off. Thanks so much for any ideas, -Steve.
