2011 yz450f exhaust recommendations ?
37 replies to this topic
  • onelik
Posted June 23, 2011 - 09:10 PM
So I'm looking around for pipes but just dont know if they're all the same or do others make a bigger difference than others. Or or if i should stick to stock pipe and should just buy the gytr programer I heard it's the same as changing pipes. Also I'm more of a desert rider than a track rider and advice would help.
  • Troutman
Posted June 24, 2011 - 07:43 PM
YOSH and the tuner :thumbsup:
  • HRC
Posted June 25, 2011 - 10:53 PM
ARROW and the tuner ! :thumbsup:
  • rickallen124
Posted June 26, 2011 - 04:46 PM
Depends on what kind of power you want. Pull longer on top? Mellower and broader or more hit? Spark arrestor required? MXA did a test and preffered the Yoshimura RS-4 and Pro-circuit pipes but that is mx. I have the Yosh and love it and yes the tuner does make a difference. You might try to find some tests and see what suits your needs.
  • SEOINAGE
Posted June 27, 2011 - 04:18 AM
Ordered an MRD last weekend, won't know how good it is for a few more weeks, but at least I know it will be built well. performance should do what the others do as well.
  • THE-OG-694
Posted June 27, 2011 - 06:44 AM
Yosh, is all that needs to be said...
  • onelik
Posted June 28, 2011 - 03:12 PM
Would the slip yosh work or should I get the full system
  • brentn
Posted June 28, 2011 - 06:40 PM
I bought a power commander five long before I bought a pipe and found a noticable difference in top end power after the install. Leaning out the fuel map and making it more precise is a great mod just like adding a pipe.
I bought an FMF 4.1 slip on later on and again noticed a much larger gain in mid-top end power.
It's been proven that the stock header flows very well, and a slip on will net the best gain for the price. If you want to save some weight then grab the full setup.
My .02 cents.
From what I have read, almost all of the slip on's are great buys!.
I wish that Yoshimura would make that duel outlet slip on for the yammy though!
  • Troutman
Posted June 28, 2011 - 07:21 PM
I would go for the full system, I got mine for under $475 (Stainless new on E bay)
  • THE-OG-694
Posted June 28, 2011 - 11:10 PM
I did the slip on first, then the full system and i could not tell the difference between the two...the slip on is cool also because it came with the removable spark arrestor...
  • Quernix
Posted June 29, 2011 - 05:18 AM
Thanks for sharing - you just saved me some cash...
What did you feel when you put the slip-on on?
  • THE-OG-694
Posted June 29, 2011 - 03:21 PM
Smooth power with a little more bottom mid and top, also i added two teeth to the rear and removed the spark arrestor...i only ride tracks so it’s unnecessary..
  • Pmason718
Posted July 04, 2011 - 08:57 PM
Anyone heard anything good or bad about the Vance & Hines XCR
http://www.vanceandh.../YZ450/xcr.html
  • Quernix
Posted July 04, 2011 - 09:47 PM
http://www.nxtbook.c....php?startid=42
Click preview.
  • Pmason718
Posted July 05, 2011 - 06:03 AM
Click preview.
Thank you thank you thank you. I wonder if anyone on here has this exhaust
  • Pmason718
Posted July 05, 2011 - 07:10 AM
Click preview.
B/c I don't have a subscription I can't read the whole article. I was able to read about 4 exhaust but the one I wanted to read about I couldn't which was the Vance and Hines
  • SEOINAGE
Posted July 05, 2011 - 09:26 AM
Looked like they clearly liked the yosh the best. I was considering a yosh but went with the MRD instead although I don't have a nice shootout report to tell me it is best, I hope it is comparable to the yosh.
  • Quernix
Posted July 05, 2011 - 12:06 PM
Mellowest power down low, more overrev. Everybody but Novices wanted more everywhere. Quietest exhaust in test.
Recomendations were Yosh or Akra.
  • Pmason718
Posted July 06, 2011 - 08:36 AM
If you someone was going to buy it for you which one would you choose Yosh or Akra and would you need a PCIII or V
Posted July 06, 2011 - 10:57 AM
How about not making the assumption that we all know what you mean by "PCIII"?
  • Hot  33 replies
  • 5 replies
  • 9 replies
