engine making wierd noises? :S
9 replies to this topic
  • corndogg
Posted June 21, 2011 - 06:57 AM
hey, so i bought a 2004 yz 450 the bike was stock when i got it, so i put a fmf pipe on it and new air intake. the bike was runnning lean the header was glowing red hot jus after a cold start. so i re jetted the bike and the took it for a ride and the bike started making a really loud vibration noise coming from the engine about 45 min into the ride. i cannot figure out what is going on. perhaps the valves need to be done again? the sound to me is a vibration coming from the engine or something slapping on something else.....any sugestions?
thanks
  • ninjaman123
Posted June 21, 2011 - 10:44 AM
Yamaha makes some wierd slapping noises in their four strokes sometimes. I have a Raptor 660 that does that and it is built to the hilt i took it in and they said its normal. Its your valves opening and closing extremely fast. If soemthing happens to it get kibblewhite titanium valves. And since it is a 450 it will be louder than most so dont worry about it.
  • dgcars
Posted June 21, 2011 - 10:57 AM
Search the FAQ with regards to your header. Don't re-jet.
Posted June 21, 2011 - 11:15 AM
Have it looked at or compare it with a couple of similar bikes to see if the noise is normal or not.
  • corndogg
Posted June 21, 2011 - 02:12 PM
should the header be red hot shortly after start up? only ideling for a minute? ive never had that happen before
  • corndogg
Posted June 21, 2011 - 02:46 PM
and by red hot i mean glowing red. even had like sparks come off the exhaust.
Posted June 21, 2011 - 03:14 PM
Normal would be red heat, easily visible in twilight, or a garage lit by two 100 watt bulbs after a minute to a minute and a half. Frankly, running too rich is more apt to cause it than too lean. More prone to it with the choke on.
  • corndogg
Posted June 21, 2011 - 03:40 PM
thanks for the input. appreciated. this bike is jus drivin me nuts!! the reason im so paranoid about it is because my last bike 3 times even after yamaha mechanics rebuilt the motor.
  • corndogg
Posted June 22, 2011 - 03:08 PM
its a 2004 yz 450 its all stock except for a k&N air filter and a fmf powerbomb header with a power core exhaust where i live is 76.2 m above sea level. any jetting suggestions would make my life allot easir.
Posted June 22, 2011 - 04:18 PM
http://www.thumperta...886#post6980886
