YZ450F brake light switch routing
No replies to this topic
  • chrispa
Posted June 20, 2011 - 03:43 PM
hey guys,
just wondering those of you with a YZ450F with rear brake light fitted, where do you run your brake light switch cabling from the rear brake lever?
I've run mine like this:
try this link if that doesn't work:
I then wedge the cable between the guard bolt and the airbox, so its away from the exhaust (cable follows the airbox grove down).
I find this a little annoying as the guard does not fit 100% flush onto the bike. I think of any other way to route the cable though, the bottom of the air box is completely sealed.
Any ideas?
Need help by Goforaride
  • Hot  68 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  36 replies
  • 0 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
