check-point stub holders
6 replies to this topic
  • stucknbaja
Posted August 28, 2003 - 07:13 PM
Do any of you guys use, or have you seen, anything kinda trick for holding check-point stubs during deset races? I'm currently using a medicine bottle with some duct tape over the top and a slit cut in that, but I have to believe there is something cleaner than this. I'm trying to come up with something myself but thought I'd check to see if anyone here had a good idea.
Thanks
  • BajaBoundMoto
Posted August 29, 2003 - 07:28 AM
Nobody mass produces one for bike guys, only car racers.
Team Green used to machine trick ones for thier factory bikes. We copied their idea and made a few which have since disappeared.
You're on the right track with the little bottle and you'll be as factory as anyone else nowdays!
  • irondude
Posted August 29, 2003 - 01:41 PM
I use the handy little nail and screw holders/containers that are sold at HomeDepot. Product is called a 'Viewtainer' They are clear plastic with a pinch and open mouth- work great with a zip tye or two. I bought the first one from a vendor at the Baja 1000 in Ensenada for $10...
HomeDepot sells them for $1....
A 35mm film canister with some duct tape over the mouth and a slit would probably work.
Must be fun riding down there after the hurricane!
hasta,
Mike
  • stucknbaja
Posted August 30, 2003 - 07:24 AM
Thanks for the ideas guys.
Not too much change after the hurricane, at least right around here. Everythings getting green now and the cows are alot happier.
  • redrdr67
Posted August 31, 2003 - 02:07 PM
There's a shop in Anaheim called McKenzie's that sells spun aluminum stub cans. I hose clamped and duct taped mine on the bars and it lasted 440 miles at one of the 500's. You can reach them at 714-441-1212.
  • Cosmo
Posted September 01, 2003 - 02:36 PM
I saw your thoughts on a custom Stub can holder. I'm almost done with one for our Baja 1000 bike.I'll send a picture once it's finished(welded).I took a clutch perch,removed material where the pivot bolt was.Took a piece of aluminum rod stock drilled and opened it up untill it became a "can".It will be welded to the "perch" so that when you are sitting on the bike it will be facing outwards towards the grip.Also,the can opening uses ared rubber cap(with a slit opening).I'll have a picture this week. Brian.
  • stucknbaja
Posted September 01, 2003 - 07:48 PM
Thanks Brian, that would be helpful.
Thanks for the phone number redrdr
  • 9 replies
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
  • 4 replies
