O-Ring Master Link Question
7 replies to this topic
Posted April 15, 2001 - 04:51 PM
I searched the archives first, hopefully didn't miss something. Also noticed that when using the search engine he can't seem to find the URL from the stuff in the list...Maybe I did something wrong?
What I am looking for is hints, tips, tricks, or secrets for getting the darn master link on. I usually pull my chain off every other ride and soak it and clean it real well. But everytime its a pain getting the clip on the master link. I have a hard time keeping the clip slots exposed when trying to install the clip. I Know, I know, I'm a retard! But if you can forgive me for that I would appreciate any non-derrogatory suggestions. Thanks, Paul :)
P.S. I'll even take some derrogatory suggestions if they work! :D
  • YZ400Court
Posted April 15, 2001 - 05:24 PM
I use small vice grips to squeeze the link together. It takes some doing, but it works.
Good Luck
Pretend it's flat and give it the gas.
  • cueball
Posted April 15, 2001 - 05:29 PM
Getting the master link on can be a real bear, especially a new chain/master link with new rubber rings!
Somebody might have something better than this, but it works for me:
Use a small socket & C-clamp to compress it on first. That is, open up a small c-clamp to the width of the chain & small socket or a small nut. Put the outside flat in place, and put the socket/nut on the outside where the first pin will come through. Put the clamp over the link & socket, then tighten.
Do this a little at a time on the front & back pins, and it'll squish into place. It tends to stay in place when you remove it, and putting on the clip is reasonably easy.
Works for me....but maybe there's a better way?
  • Tim_in_WA
Posted April 15, 2001 - 06:02 PM
I've used Cueball's method for years and it works great for me!
  • CAB
Posted April 16, 2001 - 07:41 AM
Same as above, but I use two pair of vicegrips and two 10mm nuts. Crank it down, wait, crank again, and usually the clip goes on very easy.
  • YZ400Court
Posted April 16, 2001 - 11:11 AM
Check out the chain press tool in this page from Baja Designs
[This message has been edited by YZ400Court (edited 04-16-2001).]
  • MichiganDRZ400E
Posted April 16, 2001 - 01:36 PM
I use vice grips and drill out the plate holes. Just enough to clean the hole. I sure makes it go on easier and I have never had a problem. Also I use WD40 to clean the chain after washing the bike(WD40 displaces water) Here in Michigan cleaning the bike is manditory after almost every ride. 10-15lbs. of mud. O-ring chains are lubed from the inside. Most chain lubes just act as dust and dirt collectors. If I use any lube after the WD40 cleaning I use a light oil like Triflow. Try using the WD40 without lube and you'll be suprised how clean the chain stays.
Posted April 16, 2001 - 04:12 PM
Thanks guys!
