choke idle
1 reply to this topic
  • Metalskin420
Posted June 17, 2011 - 06:59 PM
how do i set the choke idle? is there choke jetting or something? thanks.
  • William1
Posted June 18, 2011 - 03:36 AM
There is no choke idle setting.
You set your fuel screw and idle speed for a perfect hot idle.
You select a starter jet just big enough to keep your engine running on the coldest cold start.
The bike runs on the choke for maybe 20 seconds, then you switch it off as soon as the engine can run without it.
