YZ450F left to idle coolant bubbling
16 replies to this topic
  • chrispa
Posted June 11, 2011 - 12:40 AM
hey guys
I was installing a brake light in my YZ450F 2008 and after about 10 mins the coolant started bubbling so I switched it off..
I'm going to replace the coolant...
I'm really worried that I've done some damage to the engine?
  • adem188
Posted June 11, 2011 - 12:58 AM
hahahaha i done the EXACT same thing dw u didnt do damage its just that there was no air flowing and it overheated so it spilled out as long as u turned it off u will be fine thats my oppinion
  • dvn
Posted June 11, 2011 - 03:39 AM
I'm surprised it took 10 minutes! They need air moving over the radiators.
  • bendover932
Posted June 11, 2011 - 04:04 AM
While it was running,how did you know it was "bubbling"? Were u running it with the radiator cap off?
  • chrispa
Posted June 11, 2011 - 04:24 AM
it wouldnt of been bubbling for longer than 3-5 mins... the cap was on..
  • adem188
Posted June 11, 2011 - 06:12 AM
was there green smoke/liquid comming out from a hose under the bike? yes or no
  • chrispa
Posted June 11, 2011 - 06:18 AM
no smoke, just green coolant out of the overflow on the radiator onto the floor, no glowing exhaust etc. i since drained the coolant and replaced it, took it out for a ride, started first kick, responded as it always has.. i dont think ive done any damage..
  • chrispa
Posted June 11, 2011 - 06:36 AM
also do I have to bleed the cooling system to remove any air pockets caused by the boil over? I'm unsure on how to do this, is there a bleed valve somewhere on the YZ450F?
  • yz450fcranker
Posted June 11, 2011 - 07:22 AM
the cap itself is the bleed valve just add juice
  • YZPaGuy
Posted June 11, 2011 - 11:38 AM
10 minutes? Thats great. Mine will do it in 45 seconds!
  • adem188
Posted June 11, 2011 - 05:17 PM
haha really??
  • adem188
Posted June 11, 2011 - 05:18 PM
no smoke, just green coolant out of the overflow on the radiator onto the floor, no glowing exhaust etc. I since drained the coolant and replaced it, took it out for a ride, started first kick, responded as it always has.. I dont think ive done any damage..
you have not done any damage at all. Relax a little. End of thread
  • Polar_Bus
Posted June 13, 2011 - 08:27 AM
Yup, the YZF's should not be allowed to idle for more than 45 seconds or so. They will blow coolant out the cap quickly. Start your YZ give it a 30 second warm up, and get the bike moving. Ride the bike easy for another 5 min or so, then let er' rip ! :ride:
  • adem188
Posted June 13, 2011 - 11:37 PM
really? 30 seconds? thats it? y so little time?
  • Hurricane
Posted June 15, 2011 - 10:08 AM
You can idle longer than that, the manual says to let it idle for 3 minutes before doing an oil change.
Posted June 15, 2011 - 10:49 AM
The manual contains a lot of little errors like that that are carried over from one manual to another without any thought. A glaring and serious example is the recommendation to lap valves.
If you face the bike into a 10 mph wind, you may get away with idling for 3 minutes. Otherwise, I'd bet against it.
  • Hurricane
Posted June 15, 2011 - 10:53 AM
Well I've only had the bike a little over a month and have only done 1 oil change but I let it warm up for about 3 or 4 minutes and it didn't overheat or even make a gurgle. Maybe it's the Amsoil coolant or maybe I'm just lucky.:ride:
  • 10 replies
Motocross
  • Hot  491 replies
  • On Yesterday, 06:20 PM
