How can I get more top end power?
11 replies to this topic
  • onelik
Posted June 08, 2011 - 10:56 PM
So I bought a 2011 yz450f and I read many reviews on the 4th and 5th gear being flat so I'm trying to figure out how I can get more 4th and 5th gear power for those long wide open desert rides
  • onelik
Posted June 08, 2011 - 10:59 PM
forgot to mention this bike has a serious hit in first second and 3rd gear it responds excellent with the twist of the throttle
  • yz450fcranker
Posted June 09, 2011 - 03:48 AM
go downilll on 4th and get it to redline and shift to 5th it should be going pretty smooth lol get an exhaust pipe a k&n filter and a 50 tooth rear sprocket
Posted June 09, 2011 - 06:47 AM
The OEM muffler seems to be the limiting factor on the '10/'11. They use a sudden reduction in diameter at the end of the outlet as a noise cheat, and it ends up clipping power on top. The header, OTOH, seems to be just fine, so a well made slip-on is usually enough.
  • onelik
Posted June 09, 2011 - 09:49 AM
what kind of slip on do u suggest
  • Aicon YZ450F
Posted June 09, 2011 - 09:58 AM
I put a FMF GYTR on mine and it opened up the top a little. If you don't mind spending a extra few bucks put on a yosh
Posted June 09, 2011 - 10:05 AM
MRD, Yoshimura, ....
  • APlusAutoParts
Posted June 09, 2011 - 12:25 PM
i have a 50t rear sprocket and pro circuit exhaust and mine hits better on top now
  • Steel Panther
Posted June 09, 2011 - 03:32 PM
are you looking for more "hit" at the top of the rpm range or more speed?
  • onelik
Posted June 09, 2011 - 07:19 PM
More speed.
  • Steel Panther
Posted June 10, 2011 - 12:00 AM
if your looking for more top end speed a slip on exhaust may help a little, but gearing is the way to go. Try going down a tooth or 2 on the rear sprocket size.
  • Duner185
Posted June 10, 2011 - 12:39 PM
If i was buying a new exhaust i would go with the FMF they have great top end one of the cheapest places i found my is at this web site. here is a link then in the search type FMF
FMF
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • 0 replies
  • Hot  36 replies
