Cracked Swingarm
13 replies to this topic
  • blueberg17
Posted June 06, 2011 - 07:10 AM
My '08 swingarm has a definite fracture in the lower weld on the left side. Just like this guy's '06 in his thread: http://www.thumperta...=swingarm crack (go to post #9 for his pics)
Money is kinda tight after the engine rebuid, so buying a new $500 swingarm is not an option. Would a good welder be able to fix this for a reasonable price? or should I buy a used $100 swingarm off ebay?
  • RiderX
Posted June 06, 2011 - 09:41 AM
If you can pick up a good used one I'd go that route.
  • blueberg17
Posted June 06, 2011 - 09:53 AM
Yeah, that is what I originally thought. I called an Aluminum Fab shop in town and he said he does it all the time for guys. $35-$70 bucks same day done... So now I'm leaning more towards just a quick fix.
  • yz450fcranker
Posted June 06, 2011 - 01:37 PM
a quick fix is the right way round
  • KJK_JR
Posted June 06, 2011 - 01:45 PM
The only problem with used swingarms is its hard to tell if the slider where the brake caliper slides onto is worn out.
  • gabrams
Posted June 06, 2011 - 05:52 PM
There is no reason an experienced welder couldn't return this to it's original strength/reliability/quality if it's a fractured weld. I don't see it as a quick fix but a cheaper alternative to a new one. Just keep an eye on it for a while after repair.
  • BBrown626
Posted June 06, 2011 - 07:35 PM
Aluminum loses a lot of strength if welded repeatedly. If it cracks again consider replacing it.
  • yz450fcranker
Posted June 09, 2011 - 04:37 AM
aluminum weld by a real welder will last as much
  • blueberg17
Posted June 09, 2011 - 07:46 AM
I just got it welded by a custom fab shop for $40. He guarentees his work. Suprisingly, he has a lot of bikes come in for the same reason and has never seen a repeat failure(at least on his welds).
  • motoman808
Posted June 10, 2011 - 07:08 AM
my buddy owns a fabrication shop and says aluminium need to be heat treated after its welded or it will just break
  • blueberg17
Posted June 10, 2011 - 07:43 AM
like baked in an oven?
  • blueberg17
Posted June 10, 2011 - 08:18 AM
The welder I took it to has had a fab shop here in town about 20yrs. He didn't say anything about heat treatment. He told me it would never crack agian, especially with the end tubing extending inside the larger part of the swingarm a couple of inchs.
  • beezer
Posted June 10, 2011 - 08:40 AM
I've had 2 Yamaha swingarms welded and both bikes are still out there running.
I wouldn't worry about it.
Posted June 10, 2011 - 08:47 AM
It will be stronger if heat treated, yes, but it isn't any different than a typical casting if it's not. I've never had a problem with a well done weld.
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  47 replies
  • Hot  30 replies
