How many links?
3 replies to this topic
  • kev426
Posted August 25, 2003 - 08:24 PM
I got new sprockets and a chain I went with 14/49 with 114 links the chain seems a little long. stock was 14/50 with 114 links should I take out 1,2 links ? is there some magic formula to figure out how many links you need? :)
Thanks
kevin :D
  • tctrailrider
Posted August 26, 2003 - 04:56 AM
Kev,
Adjust the rear wheel all the way forward, wrap the chain around the sprockets. You will be able to see how many to remove. Adding links because you went to short is a pain.
  • jchantzWR400F
Posted August 26, 2003 - 06:08 AM
I'm sure you've thought of this, but can't you just adjust the slack out using the adjusters. It doesn't seem like 1 tooth difference on the rear would give that much slack that it couldn't be adjusted out.
  • Hick
Posted August 27, 2003 - 08:19 AM
Yeah, one link is a lot. If the chain fits on there at all it is probably the length you are going to have to live with.
