00' rear brake resv. cracked
3 replies to this topic
  • Fordtoughranger
Posted June 02, 2011 - 04:32 PM
I have seen where others have had the same issue, and is most likely caused by heat from the exhaust pipe.
I have found a replacement reservoir from an online site and they replied back stating that a Master cylinder from an 06-08 YZ250/450F should fit and has the reservoir built into the master cylinder.
Has anyone done this or heard of it?
Also has anyone made a simple heat shield to protect the factory one from the excess heat?
Thanks
  • Juscruzn
Posted June 02, 2011 - 06:55 PM
Yes the newer setup will bolt on.
I stayed with my '01 setup and used an old Harley pipe heat shield and cut a piece off to fit that still had the clamp on it and so far no problems.
search, there's a lot of info...
  • Sknight
Posted June 02, 2011 - 07:03 PM
Can't speak for fitment but my 04 450F rear master cylinder has the resv. built into the cylinder complete with a window.
  • tsorpi
Posted June 02, 2011 - 11:56 PM
the 03-06 rear master brake has internal resv. and its bolt on i have done itn with my 99'
