yzf 450 2010 suspension??
4 replies to this topic
  • biggazzafaetherigs
Posted June 01, 2011 - 04:00 PM
hi guy's,
i just got myself a 2010 yzf 450 and was looking to find what everbody is running on sag and on clickers??
i've had a search about and seen around 100mm race sag and 35mm static but would like to know if there's any magic numbers i need to be setting mine at
any advise much apreciated :smirk::ride:
  • brentn
Posted June 01, 2011 - 05:18 PM
For trails I'm running I think 19 clicks out (soft) on the compression, rebound is stock.
Shock is also almost all the way soft, forgot how many clicks out, but pretty much 1 less than full out I believe.
Works well for the trails. I weigh 205lbs without gear and the bike soaks up quite a bit of stuff.
  • REDRIDER341
Posted June 01, 2011 - 07:47 PM
sent mine to RG3 in NJ, and wow is all i can say:banana:
  • brentn
Posted June 01, 2011 - 08:16 PM
which package did you get?
  • YamaLink
Posted June 02, 2011 - 06:00 AM
I run a bit less sag than recommended, high speed compression is turned in about 1/4 turn, low speed is about middle and rebound just slow enough to handle pitching me off on big g-outs but it doesn't pack up. Weight is 170 pounds before gear, A level rider.
Front forks are raised about 4mm from stock.
On a related note, two of my rear linkage bearings were bone dry upon new-bike ride tear down. Others were just fine.
  • 10 replies
  • On January 15, 2017
  • Hot  36 replies
  • Hot  113 replies
