axle nut
14 replies to this topic
  • YamahaRideOne
Posted June 01, 2011 - 02:52 PM
Hi i have a 2006 WR450F and i need to tighten my chain but need to know how big the nut on the axle is and does this have a torque spec? thanks for the help
  • dgcars
Posted June 01, 2011 - 02:57 PM
If you are going to do your own maintenance...get a decent 6 point socket set and download a manual.
  • YamahaRideOne
Posted June 01, 2011 - 03:09 PM
i have the manual and i have a good set the nut is just bigger then anything i have
  • dgcars
Posted June 01, 2011 - 03:15 PM
I'm pretty sure it's a 27mm.
  • BajaFool
Posted June 01, 2011 - 09:42 PM
ALL fasteners have torque values. Since you have an Owners' Handbook, then it should not be too difficult to refer to Chapter 2 under Torque Specifications and find the information that you require. Along with springing (this is American slang meaning "pay money") for the appropriate socket, you might "spring" for a metric ruler.
  • cherrypicker7
Posted June 04, 2011 - 12:17 PM
27mm is equivalent to an inch and 1/16th, or a 12" Crescent or adjustable will work just fine. If you have concerns about the torque then refer to the manual, most just tighten it pretty good. Remember you may have to remove it out in the woods, think Rocky Mountain ATV/MC has combination wrenches to fit front and rear axle nuts, or make one up yourself.
  • Strattos
Posted June 05, 2011 - 02:50 AM
I know my 08 450 manual says to tighten rear axle nut to 125nm. not sure if earlier were different. Either way, as others have says - if you've got the manual it should tell you everything you need to know and more.
  • dgcars
Posted June 05, 2011 - 04:08 AM
DON'T use an adjustable spanner.
  • William1
Posted June 05, 2011 - 04:17 AM
...or pliers.....:ride:
  • danfromnb
Posted June 05, 2011 - 06:49 AM
One of the best tools in my "trail side" tool kit, and at about $10 you can't beat the price :ride:
  • yz450fcranker
Posted June 05, 2011 - 08:56 AM
its a 31.5mm go up to 32mm it works
  • yz450fcranker
Posted June 05, 2011 - 08:57 AM
tighten all the way and put a good one and a half turns
  • YamahaRideOne
Posted June 06, 2011 - 06:09 PM
i'm not to worried about the torque spec i know thats 90 ft lbs and i'm not to worried about getting it off on the trail i don't think getting it off will be a problem, And thanks for the size ill pick one up and see if it works :ride:
  • dgcars
Posted June 07, 2011 - 02:08 AM
???:ride:???
  • YamahaRideOne
Posted June 07, 2011 - 05:09 PM
???:ride:???
yes i figured that out after my last post im almost positive its a 27mm now
